Re: Strut Rod Bushings Moog Which Direction?
[Re: CYACOP]
#1162026
01/21/12 05:31 PM
01/21/12 05:31 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
According to the instructions in my TRW (Made in USA-gasp!) box, the "centering collar" goes on the control arm side. Both outer washers (concave side) face control arm. Wide side of bushings face the frame.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#1162028
01/21/12 09:52 PM
01/21/12 09:52 PM
Posts: 3,958 SW Fla.
CYACOP
SW Fla.
Tim
That's the way I ended up putting them in. Thanks for everyone's help. DJ
[Re: I_bleed_MOPAR]
#1162029
01/22/12 03:22 PM
01/22/12 03:22 PM
Posts: 22,717 Bitopia
jcc
Bitopia
Tim
Concave meaning the "hallowed out" side, I have almost always seen facing away from control arm. Additionally I removed my brake struts last weekend, and surprisingly they are clearly stamped by mopar concave side faces away from control arm. This however makes no sense to me, unless a lot of progressive slop in this area is desired, but i can't imagine why, and then of course why do we bother with the Reilly hard pivot upgrades? I hope I've got this right, and it will be a few days before i can get camera on these above mentioned stamped washers.
[Re: jcc]
#1162030
01/23/12 09:55 AM
01/23/12 09:55 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
They're stamped "This side to rubber"
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
