Re: 400 block 440 Mains
[Re: dmking]
#1161795
01/21/12 01:31 AM
01/21/12 01:31 AM
Posts: 443 Long Island, New York
cochez
super gas
super gas
well if they do not want to do it on the main caps being on the thin side put a good stud girdle on it with main caps. then they have to be bored and have more metal. maybe they will like that.
440jim did it to his 400 , no problems reported , that I have seen . A plus is better choice of main bearings .
I actually copied his build way back when...and hoped he'd chime in... if he remembers me... I have a place to do it (Weston Machine) and also the main girdle from Chenoweth... I'm trying to get this project up and running again... Really I would like to see some pics if anyone has any? Or links I could check out......
[Re: AndyF]
#1161798
01/21/12 03:53 AM
01/21/12 03:53 AM
Posts: 2,091 Delray beach, Florida
Performance Only
it's not really a big deal IMO. back before I bought the CNC, we just did them the old fashioned way. the CNC makes it a little easier now. when 440jim bought his Callies crank from me we discussed the option of opening the blocks mains so he wouldn't have to cut the journals on the crank. IMO and obviously Jim's as well, it was better to cut the block. i think the longevity of his engine as well as the performance speaks for itself.
machine shop owner and engine builder
[Re: Performance Only]
#1161799
01/21/12 10:44 AM
01/21/12 10:44 AM
cochez
super gas
super gas
If This is Dan? I got my Crank, Rods & Pistons from you also. (Have not put it together yet) I haven't been up on the latest and greatest for the last few years.... I'm trying to reclaim all the data I've lost over the years and finally get this up and rolling again. This is Rich if you remember me????
[Re: cochez]
#1161801
01/21/12 12:18 PM
01/21/12 12:18 PM
Posts: 16,925 NC
440Jim
NC
That is who I used. Highly recommend that shop. They will get it done right, and turn it around quickly. No 3 month wait like some shops...
[Re: 440Jim]
#1161802
01/21/12 12:25 PM
01/21/12 12:25 PM
cochez
super gas
super gas
My 511 CID low deck (4.375 x 4.250 stroke) has aluminum main caps and enlarged to 440 size. I run a Callies crank. This block has almost 800 passes now. I was so happy back in the winter of 2010-2011 I did the same main change to my spare 400 block.
Yes! I copied your short block plans... good to hear no issues my stuff has been on the shelf since 2006... Did you have to notch the block at all and what kind of oil system do you run... I was suposed to drop the block of today but Snow is in the way...
[Re: 440Jim]
#1161804
01/21/12 10:15 PM
01/21/12 10:15 PM
cochez
super gas
super gas
As I recall, the rod bolts (2.200 H-beam) cleared the cylinder bores, but I ground clearance there anyway while I was preparing the block. I did have to just touch the oil pickup boss on the block, picture attached. I run a 1/2 NPT Moroso internal pickup. I had the Callies 4.250" crank counterweights turned down to 7.14" dia before balancing, 2185 gram bobweight.
did you turn the counterweights down to reduce mass? Or was there clearance issues?
[Re: cochez]
#1161805
01/21/12 10:29 PM
01/21/12 10:29 PM
Posts: 16,925 NC
440Jim
NC
The counterweights need to be turned down to 7.25" dia to clear a low deck block. Or grind clearance in the block, or put 3/8" bevels on the counterweights. But since the bobweight is so "low" (for a steel rod motor), reducing the counterweights helps balance the crank without putting big holes in it. I tell everyone, each crank brand, stroke, and bobweight is different. So, go carefully when cutting smaller than 7.25" dia. The shop actually checked it on the balancer at 7.20", before cutting the dia down even farther. Then a fine balance with a shallow hole.
