Re: welding ali heads
[Re: challenger73400]
#1161255
02/21/12 12:25 AM
02/21/12 12:25 AM
Posts: 161 New Zealand
dart6
New Zealand
The heads in question are mine.They were some of the earlier stealth ones that had overhang in the chambers. I thought i was in good hands with rebel and his mate.These heads are now stuffed .They can possibly be fixed but very, very doubtful,it would be cheaper buying new heads.The guy who welded them did piss poor welds that are full of holes and would have fallen out eventually if they were used. Now anyone who is welding on ali heads should know that you can only use one particular rod. Why because the others will soften the ali. How soft, read on. I sold these heads on to someone who was in the process of having a 440 built.His builder did a vacuum test and one valve was leaking badly. He pops the valve and sees that the seat has been welded on so he then takes a closer look and sees all the crap welding. So next he gives it a hardness test. Now a new ali head will give a typical rn hardness reading of 120. Experienced head guys i have talked to, one being solely a head guy doing a ton of performance work the other a machine shop/engine builder who runs the worlds fastest SB ford have said they're junk. Tony said the minimum with 9.5 to 10.1 CR would be a hardness of 80 to 85. When i told him mine measured at 40, he just had the one word, Junk
Speaking to the heat treatment people. Anealling is not an option because the degree they bring it up to is just about where ali melts.They do other heat treatments but they can't say if it be effective. What ever treatment you used if you wanted to, the guides and seat inserts would have to be removed. Most of the inserts would have to replaced because if you look in a stealth head thay are machined where they overlap one another. So that's what i mean by what i say above, that the cost with all this additional work doen't make it feasable and you still don't know if you are going to the hardness plus you'd still need additional welding as well. I'm out $2100nz because of this. I didn't hesitate to refund the guy who bought these, he lives about 1000 miles away. He payed the shipping there and back so i let him keep the new higher psi bolt kit. Oh yeah i let him keep the head, manifold and exhaust gaskets as well that rebel initially gave me but then he just accumulates those as he has no need for them. He only uses 1-2 gaskets out of a set but it's a cheaper way to buy them he says. It's the least i could do as i know that shipping was expensive I will post some pics if i can work it out, also you can find my original post for help on these head on this subforum
Thx Brett
[Re: dogdays]
#1161259
02/28/12 02:23 AM
02/28/12 02:23 AM
dart6
New Zealand
Seems to me that the problem as described is not the heads but the welder. Sorry to hear of your problems. R.
especially the welder, there's several rods for welding ali but only one for doing heads, i trusted these guys to know what they're doing
[Re: dart6]
#1161260
02/29/12 04:29 AM
02/29/12 04:29 AM
Posts: 7 nz
jaws
nz
Yeah i was talking to a guy who knows the guy who bought them off you.Haha he thought he was going to have to kiss his money goodbye. I'll tell you what you've got alot of kudos down south here and with the mopar community for doing the honourable thing. Wish i could say the same for rebel and his mate,i see he posts alot here and bet he has seen this . By the way i've pointed this thread out to several others as we"d all like to see you treated decent, hope you don'y mind Wish i'd come to this site ages ago as there's a ton of great info and stuff to buy
later
[Re: dart6]
#1161261
02/29/12 12:08 PM
02/29/12 12:08 PM
Posts: 4,206 New York
polyspheric
New York
there's easily 20 rods for welding ali, and more than one for doing heads Has nothing to do with the casting being a head, it's: 1. the heat and stress environment 2. the alloy
Boffin Emeritus
[Re: polyspheric]
#1161262
02/29/12 01:42 PM
02/29/12 01:42 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
3. Quality of the part being welded ?
[Re: polyspheric]
#1161263
03/01/12 05:59 AM
03/01/12 05:59 AM
Posts: 7 nz
jaws
nz
that's all very well but obviously if your'e using a rod that makes in this case an alloy head soft as butter your'e using the wrong rod for the job which in this case made the guys heads JUNK What is your point
