What will it make? #1161157
01/20/12 01:19 AM
01/20/12 01:19 AM
Louisville, MS
Dustedu Offline OP
Dustedu  Offline OP
Louisville, MS
We takin engine to dyno 29th, what you think it will make
440" r3 16:1cr .900" lift w/ 2 1050's on gas
See who gets closest...
Re: What will it make? [Re: Dustedu] #1161158
01/20/12 05:18 AM
01/20/12 05:18 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I'll bite 900 i'm never good at this so i'll give it a
p.s engine looks killer
Re: What will it make? [Re: racerx] #1161159
01/20/12 05:31 AM
01/20/12 05:31 AM
Arizona
Chris'sBarracuda Offline
Arizona
440" x 2.2 = 968 @ 8200..
Chris..
Re: What will it make? [Re: Dustedu] #1161160
01/20/12 07:13 AM
01/20/12 07:13 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Need more information.
Re: What will it make? [Re: S/ST 3040] #1161161
01/20/12 09:35 AM
01/20/12 09:35 AM
Louisville, MS
Dustedu Offline OP
Dustedu  Offline OP
Louisville, MS
What you need
4.185 bore
W9rp's rfd over 400 cfm
Beck sheetmetal intake
Re: What will it make? [Re: Dustedu] #1161162
01/20/12 10:04 AM
01/20/12 10:04 AM
tboomer Online work
tboomer  Online Work
895??
Re: What will it make? [Re: Dustedu] #1161163
01/20/12 10:28 AM
01/20/12 10:28 AM
Delray beach, Florida
P
Performance Only Offline
P
what will it make you ask? hmmmm. i say it will make your wallet go empty and your car go fast.
machine shop owner and engine builder
Re: What will it make? [Re: Performance Only] #1161164
01/20/12 10:33 AM
01/20/12 10:33 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Ballpark figure.........950.
Re: What will it make? [Re: Dustedu] #1161165
01/20/12 11:43 AM
01/20/12 11:43 AM
S/ST 3040 Offline
S/ST 3040  Offline
860 @ 8000.
Re: What will it make? [Re: S/ST 3040] #1161166
01/20/12 11:47 AM
01/20/12 11:47 AM
ohio
all spooled up Offline
ohio
965 at 8600
Re: What will it make? [Re: all spooled up] #1161167
01/20/12 01:00 PM
01/20/12 01:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
860-875 with given info. So to give an exact number 867.5 UNLESS you built it to operate in the 8500-1000RPM range. Then I think you would be looking at a 950-970 combo. All a guess though with no head flow and cam info.
