Re: Best Battery for a street car when moving to rear
[Re: ahy]
#1161042
01/20/12 12:56 AM
01/20/12 12:56 AM
Posts: 669 Michigan, USA
ramman5600
Michigan, USA
I used a Red Top. I like the no leak/no spill design for inside the car/trunk. It seems like most standard type batteries leak sooner or later and the damage is hard to fix in the car. Plus, it has plenty of cranking power.
I have a hit and miss record with Optima. Any other brands that have been successful?
-C
[Re: ramman5600]
#1161044
01/20/12 10:18 AM
01/20/12 10:18 AM
Posts: 2,826 NY usa
540challenger
NY usa
-C
I use to love my red top until they switch to mexcio plant i think then they became hit or miss.
I know run the exide gel battery no problems and i love it!
[Re: WheelsUp73]
#1161049
01/20/12 06:44 PM
01/20/12 06:44 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Food for thought...in my opinion, if I was going to go through the trouble and expense of relocating a battery, I'd just use a standard, heavy battery, afterall, it puts weight over the rear, which is "good weight"
if you're going to spend big bucks on a light weight battery, then just leave it up front.
I wonder if you actually gain anything weight wise, by going to a lighter battery, then adding 40 feet of heavy copper wire to run up to the starter, and then from the alternator back to the battery.
**Photobucket sucks**
[Re: 70Cuda383]
#1161050
01/21/12 02:01 AM
01/21/12 02:01 AM
ramman5600
Michigan, USA
I agree with the lighter not being critical, but I should have stated a little smaller as it is going in the spare tire well in the wagon.
-C
