69 Charger 1/4 Glass #1160994
01/19/12 09:34 PM
01/19/12 09:34 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Those rubber washers that go between the glass and the metal bracket where the bolt goes thru the glass... does any one sell these? thanks
Re: 69 Charger 1/4 Glass [Re: JohnH] #1160995
01/19/12 11:18 PM
01/19/12 11:18 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
The tubular washer that fit on the bolt was actually radiator overflow hose from the factory-look real close and you can see the ribs. You can make some foam or ubber washers from flat stock.
