Stupid question...been too dang long. #1160882
01/19/12 08:04 PM
01/19/12 08:04 PM
beedees Offline OP
beedees  Offline OP
Starter on 440 (1967)....backed it out,went to pull it back in ...starter clicks rapidly but no crank. Jumped it the relay and the starter runs but doesn't engage. Battery is good Solenoid on starter maybe? I'm old and tired and got CRS (can't remember stuff) What now ? Thanks
Re: Stupid question...been too dang long. [Re: beedees] #1160883
01/19/12 10:34 PM
01/19/12 10:34 PM
there's a poor connection inside, not enough amperage being passed. Open it up & good visual & should be apparent EDIT 1st, check (clean if need be) the posts/cables
Re: Stupid question...been too dang long. [Re: beedees] #1160884
01/19/12 10:34 PM
01/19/12 10:34 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Check Battery voltage? Bad Batt = NFG
Re: Stupid question...been too dang long. [Re: Bill MeLater] #1160885
01/19/12 11:55 PM
01/19/12 11:55 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
The bendix is not kicking out the starter gear to engage the flywheel, is that whats going on? How long has it been sitting?
Re: Stupid question...been too dang long. [Re: None2Slow] #1160886
01/20/12 12:18 AM
01/20/12 12:18 AM
beedees Offline OP
beedees  Offline OP
Jeez, stupid me. 12.8 volts on a MM does not mean a batt. is good. Stuck the load-checker on it and it barely got warm. Battery is about two months old. ROAD TRIP back to Wally World. Thanks all
