REMOVING PAINT FROM FENDER TAG ? #1160693
01/19/12 02:28 PM
01/19/12 02:28 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
ok i found a 70 rt chall that has been in the same family since '71 but has been repainted twice and the fender tag is not very easy to read.
what would be the easiest way for them to expose the digits on the tag without damaging the surrounding paint?
Re: REMOVING PAINT FROM FENDER TAG ? [Re: CUDA8U] #1160694
01/19/12 02:29 PM
01/19/12 02:29 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Unscrew it and soak it in paint stripper ?
Or just read it from the back side as well...
Re: REMOVING PAINT FROM FENDER TAG ? [Re: OzHemi] #1160695
01/19/12 03:38 PM
01/19/12 03:38 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
soak in brake fluid over night or until it is gone the paint that is not the tag
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: REMOVING PAINT FROM FENDER TAG ? [Re: 340SIX] #1160696
01/19/12 03:43 PM
01/19/12 03:43 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
well i got thinkin.....what if he held the back side of the tag up to a mirror.....could he read it then?
or placed a paper over tag and sketched over it with a pencil?
Re: REMOVING PAINT FROM FENDER TAG ? [Re: CUDA8U] #1160697
01/19/12 03:49 PM
01/19/12 03:49 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Take a reasonably high res picture of the back and use software to flip it. Very simple to do.........
Re: REMOVING PAINT FROM FENDER TAG ? [Re: Jim_Lusk] #1160698
01/19/12 04:00 PM
01/19/12 04:00 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
hopefully he could do that.......took me an hour to type this with one finger
Re: REMOVING PAINT FROM FENDER TAG ? [Re: CUDA8U] #1160699
01/19/12 04:31 PM
01/19/12 04:31 PM
USA
big-block-dave Offline
USA
Why take the paint off, just read it from the back, very easy. You don't have to be a scientist to do it..........I've used a glass bead blaster to remove paint/rust on several. Good luck let us know what ya got there!
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: REMOVING PAINT FROM FENDER TAG ? [Re: Jim_Lusk] #1160700
01/19/12 04:38 PM
01/19/12 04:38 PM
East Bay, N. Cal.
calmopar Offline
calmopar  Offline
East Bay, N. Cal.
Been there, done that, works great.
Trying to enjoy life!
Re: REMOVING PAINT FROM FENDER TAG ? [Re: calmopar] #1160701
01/19/12 05:28 PM
01/19/12 05:28 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
if the car is getting restored or fixed up, why not media blast the paint away? bead blasting should remove the paint, but shouldn't mess up the stamped metal. if it does, then you're probably using steel shot instead of glass bead!
**Photobucket sucks**
Re: REMOVING PAINT FROM FENDER TAG ? [Re: 70Cuda383] #1160702
01/19/12 05:58 PM
01/19/12 05:58 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1) the mirror trick then flip works well
2) why not just strip it?
3) I'm sure bead blasting would work, but I would chemically strip it myself
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: REMOVING PAINT FROM FENDER TAG ? [Re: DPelletier] #1160703
01/19/12 06:58 PM
01/19/12 06:58 PM
midwest
68427vette Offline
68427vette  Offline
midwest
sometimes you have this: and two of those options are not going to work,, i used the MIRROR trick,, because my photobucket, i dont think has a "MIRROR IMAGE" function
post some pics!! if you pass on the car,, rex, over on for e bodies,only, is looking for a project car,, BAD!!
Re: REMOVING PAINT FROM FENDER TAG ? [Re: 68427vette] #1160704
01/19/12 09:27 PM
01/19/12 09:27 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
It's a real nice driver with 2 repaints so tag is hard to read
friend put me onto it as it's not advertised
the owner got it from his brothers estate and thinks the leather seats, louvers and go wing are factory options
going to put deposit once i get the tag pic
Re: REMOVING PAINT FROM FENDER TAG ? [Re: CUDA8U] #1160705
01/20/12 12:16 AM
01/20/12 12:16 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
If its been repainted with the tag in place, then unscrewing it will mess up the paint. The paint will need to be cut of the edges before removing, but you will still have a place for the paint to start to lift later.
