Indy Reconditioned 906 Heads - Has Anyone Used Them? #1160666
01/19/12 02:02 PM
01/19/12 02:02 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
I'm considering buying a ported rebconditioned set from Indy. I have several sets to trade in to offset the cost. My build is a mostly stock 440 for a car that I plan on driving more often than just weekends or car shows. Compression will be in the 9.5 to 10.0 range. I can have a set rebuilt locally, but no one local can CNC port heads. I just want the most bang for my buck.
Thanks,
Jerry
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: 3_RTs] #1160667
01/19/12 02:06 PM
01/19/12 02:06 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Where have you seen these and how much are the going for? I looked on Indy's website but cant find them. I'm interested...
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: GTX MATT] #1160668
01/19/12 02:10 PM
01/19/12 02:10 PM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
It's actually under the 'aero-head' part of the Indy ads in MCG and Mopar Muscle. On the latest MCG its on page 25.
Jerry
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: 3_RTs] #1160669
01/19/12 02:14 PM
01/19/12 02:14 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Hmmm strange, I wonder if these are just the aero heads that people have been buying? Price is cheaper though...
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: GTX MATT] #1160670
01/19/12 02:15 PM
01/19/12 02:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Put a set of Aero heads on my kids built 360 a few years back.They were decent heads for the price.Rocky
Chrysler Firepower
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: therocks] #1160671
01/19/12 05:35 PM
01/19/12 05:35 PM
Central NC
gch Offline
gch  Offline
Central NC
Muscle Motors is doing cnc on iron heads.I would buy from them before I would Aerohead.
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: gch] #1160672
01/19/12 06:14 PM
01/19/12 06:14 PM
dogdays Offline
dogdays  Offline
Unless you have a class racer or other application that mandates stock heads I cannot see any way you can do better than a new set of aluminum heads. Core prices for cast iron heads are low and shipping is high. Plus, Aerohead might, but I haven't run into any head rebuilder that wants to buy extra cores. Got a stack of used cast iron heads in my garage that's worth scrap only.
Porting a stock iron head costs more than the complete aluminum replacement head.
R.
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: dogdays] #1160673
01/19/12 08:31 PM
01/19/12 08:31 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Have you called Aerohead?? They didn't buy cores when I called them a month ago. Hopefully you'll have better luck than me.
MuscleMotors does. They told me they'd pay $50.00 a set, core value. And that was towards a stroker kit purchase that we were discussing. Not sure if it was contingent. And it WAS contingent on whether they felt their current supply was low enough to need any.
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: 3_RTs] #1160674
01/20/12 12:44 AM
01/20/12 12:44 AM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
Not sure if its still in effect, but Aerohead/Indy used to charge an extra $100 for the 906/452 castings. And I have to agree, by the time you buy the remanned heads and have them ported, you are close to new aluminum territory...
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: 3_RTs] #1160675
01/20/12 01:10 AM
01/20/12 01:10 AM
Arlington Heights, IL
Ovalracer68 Offline
Ovalracer68  Offline
i bought a set of aerohead 340 x heads and bolted them on a fresh motor only to have milkshake oil after break in. had the the heads magnafluxed locally and one was cracked. no luck on the return/refund. id look into aluminum.
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: Ovalracer68] #1160676
01/20/12 10:08 AM
01/20/12 10:08 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
anything you buy from Indy has to be thuroughly checked out before use.
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: bonefish] #1160677
01/20/12 11:29 AM
01/20/12 11:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That goes for anything you buy from anyone .
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: JohnRR] #1160678
01/20/12 11:36 AM
01/20/12 11:36 AM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
Thanks to everyone for your responses! Aluminum is looking more attractive.
Jerry
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: 3_RTs] #1160679
01/20/12 12:40 PM
01/20/12 12:40 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Thanks,
Jerry
Dwayne (fast68) has a few sets for sale in the BB parts for sale section here if you want to get an idea of what a ported set of OEM heads can cost and flow. For a mostly stock build I would get a good valve job and call it a day.
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: THESHAKERPROJECT] #1160680
01/20/12 01:56 PM
01/20/12 01:56 PM
Holly/MI
Holly/MI
Except, every set of BB Mopar heads I've ever had freshened up needed valve guides and some of the tips where the rocker rub can be pitted quite often.
CNC'ing heads for "mostly stock" build is too pricey. Buy an electric Sears die grinder, a few carbide cutters and have at it if you really want a set of ported heads. Just opening up the bowls can make a big difference. If you hurt a head, big deal, factory iron castings can be had around here for $50 a pair or less.
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: Dean_Kuzluzski] #1160681
01/20/12 02:44 PM
01/20/12 02:44 PM
San Antonio, TX
CurYellowBird Offline
San Antonio, TX
I'm having a set of 452 large valved heads coming in from Indy's "aero head" dept. today. Let you guys know how they look.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: Dean_Kuzluzski] #1160682
01/20/12 05:05 PM
01/20/12 05:05 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Dean, Didn't know sears had an elec. die grinder, would you happen to have a part # because i've tried googling there tools & come up jack squat. Thanks.
Found this, seems to be the only one sears offers for 192.00, nice rig, but for 250.00 you can buy a 30 gal. compressor at lowes & a 19.95 die grinder, then the compressor will come in handy for other things.
http://www.sears.com/shc/s/p_10153_12605...p17=00981824000
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: joedust451] #1160683
01/20/12 05:18 PM
01/20/12 05:18 PM
IL
furious70 Offline
furious70  Offline
IL
Several guys on the C body board have them and they seem to be a reasonable deal for someone just wanting a stock rebuild. Nobody had them come apart on them. They aren't cost effective if you buy them and then send them off to be ported.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: furious70] #1160684
01/20/12 05:33 PM
01/20/12 05:33 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Re: Indy Reconditioned 906 Heads - Has Anyone Used Them? [Re: joedust451] #1160685
01/20/12 06:26 PM
01/20/12 06:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The old Craftsman die grinder was discontinued a couple years ago .
