Passenger compartment Exhaust???? #116060
09/06/08 03:51 PM
09/06/08 03:51 PM
Utah
W
WAJ Offline OP
WAJ  Offline OP
W
Utah
I have a 71 Hemi Cuda recreation and have a problem I can't figure out. . . .I'm getting exhaust smells in the passenger compartment when I hit the gas. I've had all the exhaust checked out and there are no leaks.
Is this maybe not exhaust but instead, fumes coming from the breather cap or something like that???
Can't figure this out and it's nasty every time I get on it. Can anybody give me some advice please?
Thanks.
Re: Passenger compartment Exhaust???? [Re: WAJ] #116061
09/06/08 04:15 PM
09/06/08 04:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Hows the trunk seals, body plugs, etc? Where does the exhaust exit?
Re: Passenger compartment Exhaust???? [Re: WAJ] #116062
09/06/08 04:28 PM
09/06/08 04:28 PM
you might put the rear up on stands open the hood put it in gear & get on it & see if you see anything. the car wont be moving but the source may be obvious enough for you to see it.
Re: Passenger compartment Exhaust???? [Re: WAJ] #116063
09/06/08 04:42 PM
09/06/08 04:42 PM
NH
72challorange Offline
He's Game
He's Game
NH
How about the cowl vent seal?
Tom
Re: Passenger compartment Exhaust???? [Re: 72challorange] #116064
09/07/08 02:54 PM
09/07/08 02:54 PM
Utah
W
WAJ Offline OP
WAJ  Offline OP
W
Utah
Good thought--Thanks a lot!!!
Re: Passenger compartment Exhaust???? [Re: WAJ] #116065
09/07/08 04:35 PM
09/07/08 04:35 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Had the same problem when I had a fiberglass trunk - poor seal.
Gasses were worse with the windows down. Since it was a Street/Strip car. I already had the speaker holes blocked and a firewall behind the back seat. Finally, I made cardboard covers to fit between the 1/4 panel and the wheel housings inside the trunk to keep fumes from coming forward into the car. I could not believe how much a little cardboard and duct tape helped!
Scott
Re: Passenger compartment Exhaust???? [Re: ProStDodge] #116066
09/07/08 05:14 PM
09/07/08 05:14 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
where does the exhaust exit at??
I am truckless..
Re: Passenger compartment Exhaust???? [Re: ProStDodge] #116067
05/25/09 06:25 PM
05/25/09 06:25 PM
Utah
W
WAJ Offline OP
WAJ  Offline OP
W
Utah
Scott:
You were right on the money. I put some Dynomat behind the seat a couple of days, finally, and it took care of the problem.
Thanks!
