Anyone using a holley ultra HP aluminium carb
#1160526
01/19/12 02:26 AM
01/19/12 02:26 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
as the post heading says - is anyone using one of these yet for street/strip. they do seem priced right and i think my 825 mighty demon might be in for a change as it has become more niggley to tune. Specifically i am asking about the 850 ,#8084 , model.seems to be as big as a hp1000 copied from Holley :
Important note: Venturi sizes vary considerably from previous Holley i.e new 950CFM is larger than the previous 1000CFM, the new 850CFM is larger than the old 950CFM etc.
Part # Venturi Diameter Throttle Bore Description
0-80803BK 1.375” 1.687” 750 CFM Shiny Aluminum Ultra HP - with Black Billet
0-80804RD 1.562” 1.750” 850 CFM Shiny Aluminum Ultra HP - with Red Billet
0-80805RD 1.625” 1.750” 950 CFM Shiny Aluminum Ultra HP - with Red Billet
By the way i have tried a hp950,smaller then my 825, and lost 3/10's plus MPH thoughts
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Anyone using a holley ultra HP aluminium carb
[Re: AndyF]
#1160528
01/19/12 03:31 AM
01/19/12 03:31 AM
tex013
Sydney,Australia
thanks Andy, i remember you saying some things when they were released have you found any benefit to plugging the rear PV and just jetting ?or is using the PV an economy (ha ha )/cruise related item ? Tex
