Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: Locomotion] #1160355
01/19/12 01:37 AM
01/19/12 01:37 AM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
We're just saying that the distribution of that mass away from the centerline will affect how quickly the rotating assembly can be accelerated.
Yeah, I know. And That's incorrect. If the moment of inertia is the same than rotational acceleration is the same. This is just high school physics.
If you want to keep the mass closer to the centerline you'll need to add more of it to keep balance.
This post is available in double vision where drunk.
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: bwdst6] #1160356
01/19/12 01:57 AM
01/19/12 01:57 AM
Delray beach, Florida
P
Performance Only Offline
P
you would really need to understand how engines are balanced to understand why it's not as simple as you think.
here's a little more info compliments of the internet.
Moment of inertia is the term used to measure or quantify the amount of mass located at an object's extremities. For example if all the mass of an object was located in a small compact size (like a lead ball) its moment of inertia would be small compared to the same amount of mass shaped into a dumbell. Because a dumbell has most of its mass located farther from its center. But there is a "qualification" here. Moment of inertia is calculated relative to a hypothetical spin axis. Once you choose the spin axis then you calculate the moment of inertia by multiplying the mass times its distance to the spin axis squared; I = MR^2
So in the example between the sphere and the dumbell the moment of inertia of the dumbell would be significantly larger relative to a spin axis perpendicular to the dumbell length. If you instead choose your spin axis to lie thru the dumbell parallel to its length then its moment of inertia,relative to this axis, would be much smaller because the mass would be located closer to that axis. And ,in fact, it might even be smaller then the moment of inertia of a sphere about an axis thru its center.
A way to store kinetic energy is with a spinning object. In calculating how much energy would be stored in a spinning object the energy is proportional to the moment of inertia. So all other things being equal you would choose a spin axis and object shape that gave you the largest moment of inertia for maximum stored energy.
machine shop owner and engine builder
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: bwdst6] #1160357
01/19/12 02:47 AM
01/19/12 02:47 AM
Nevada
dezduster Offline
dezduster  Offline
Nevada
An easy way for a high school class to prove this would be to remove a broom stick from your broom. Drill a hole in the center of the end, install a lag screw into hole cut the head off the screw. Now chuck a cordless drill motor up. Now pull the trigger as fast as you can and feel how little rotational resistance and how quickly it reaches top RPM. Very little resistance felt and up to speed quickly.. REMOVE CUT OFF LAG SCREW!! Now drill a 3/8 hole in the middle of its length, install 3/8 bolt into the hole, tighten the nut and bolt so the handle will not spin on the bolt. Be sure to use a bolt long enough for the same drill motor to chuck up to. Pull the trigger feel the rotational force act apon your wrist how long did it take to reach top speed? Much more force and much longer. Smaller counter weight good. Larger bad even if its same weight. Class dismissed.
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: Performance Only] #1160358
01/19/12 02:47 AM
01/19/12 02:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: JohnRR] #1160359
01/19/12 02:58 AM
01/19/12 02:58 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Of course - if XYZ Crankshafts wanted the crank lighter, they would have done it themselves.
Remember, these are the people who carefully contour their throw arms and counterweights exactly the same on the leading and trailing edges (examine some photos), because engines sometimes run backwards...
I'll learn eventually that some requests for comment actually mean "please tell me that the decision I've already made is right".
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: polyspheric] #1160360
01/19/12 04:25 AM
01/19/12 04:25 AM
Me thinks we have a person on here discussing theory versus real world experiences Not all "theorys" are accurate, especially when it comes to racing Do you know how much a NASCAR Cup crankshaft weighs? Have you ever seen a state of the art racing crank that is pendulum cut and made to be as lightweight as possible? And had the counterbalances moved off center to extend crankshaft life at 9000 RPM+ Lots of modifying parts after the all theorys are outrun (thrown out to go faster)
I like the idea that we never outrun progress, if we keep our minds open to learning and experimenting
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: bwdst6] #1160361
01/19/12 06:13 AM
01/19/12 06:13 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Yes, I would do it your way, and it is also proven (refer to Cab Burge below) in the racing crankshaft where they put the weight in the periferi (mallory metal on pendulum throws), even undercut the throws to take away dead weight. Turning down the throws on another engine is going in the opposite direction, It is all about balancing forces most efficiently, and get the total weight as low as possible.
Another way to do it is like Frod and GeM do, to save an ounce of cheap material (to gain profit) by putting the mass externally to the damper and flexplate. Increases stress (if you can really say these engines are stressed!) but saves on total weight. Most efficient way to reduce the crankthrow for total weight saving would be to cut the sides from them, and keep the mass opposite of the crankpin where it generates most of the counterforces for balancing the rod/piston assy.
My
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: Oyvind Mopar] #1160362
01/19/12 07:57 AM
01/19/12 07:57 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Technically/Mathematicly, that line is correct.
But not in real life.
Because, going from stock to a performance engine, balancing a (stock or new) crank never means 'adding' weight somewhere.
If you need to do that, you've screwed up earlier and now need to fix your mistake.
Race parts are pretty much always lighter than factory parts.
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: SCATPACK 1] #1160363
01/19/12 10:23 AM
01/19/12 10:23 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I'm just curious for the sake of being curious here...lol...I know some engineers, I know some very well " entrenched" shops who do some pretty technical builds shall we say,I know some NASCAR guys, I know some everyday guys who build a lot, I know some manufacters that BUILD and engineer these cranks, and I have my own 27 years experience and so forth and my current engine shop.
My simple question is here, how many of the guys responding own, operate, or HAVE operated a crank balancer? Not just watched one run, not watched their crank get balanced, but actually DID it?
We have 27 something responses, lets see how it shakes out.
How many guys have built over 100 engines, over say 35 engines, and how many maybe 5 or less engines?
My opinion is there is a TREMENDOUS mix of theory and reality here. What SHOULD work, what COULD work, and what DOES work.My point being, both sides have valid points, but I think in REALITY, in an engine, under load, accelerating down a track, things arent always as assumed. I know some things ( that I am not going to get into a debate on...lol) thaty absolutely DO work, in a stock eliminator car, that most of you would say is wrong.It goes against much of the theory, but in a practical mans thinking, makes sense.It revolves around the 4 speed components, and involves some of what is being discussed here.
No finger pointing, just some things that popped up in my mind while reading this. I have my own curiosity is all.....carry on
Hey, its cold and wintertime, I'm just thinking.
RIP Monte Smith
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: CompWedgeEngines] #1160364
01/19/12 11:03 AM
01/19/12 11:03 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
I am in the 5 or less category.
To answer the OP question, I would say the least technical answers would be 1: for clearance issues, and 2: to aid in the balancing procedure. After that I would guess to modify the effects on acceleration. But then again, I am not an engine builder, nor do I claim to be.
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: CompWedgeEngines] #1160365
01/19/12 11:06 AM
01/19/12 11:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have actually balanced 4 cranks(my own stuff) on
a balancer(using the shops balancer)before that
they (shop) did the balancing and I've built a
FEW engines
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: MR_P_BODY] #1160366
01/19/12 11:46 AM
01/19/12 11:46 AM
Norway (old world)
Norway (old world)
I am a mechanical engineer MSc, and own my enginebuilding shop. I have a crankshaft balancer, and do most type of jobs. I would fit in the 35+ engines category since the last 3 years in business (plus a number of engines for myself and friends since 1973), spread on different brands but mostly Mopars. I have also worked myself up in the practical machining and engine building, and enjoy Moparts and all the good comments here from us oldtimers. And, I do not think there is a mismatch between theory and practice, it is a matter of using the right comparisons.
Re: WHY WOULD U REDUCE CRANK COUNTER WEIGHTS [Re: BigBlockMopar] #1160367
01/19/12 12:26 PM
01/19/12 12:26 PM
Backwater, PA
bwdst6 Offline
bwdst6  Offline
Backwater, PA
That's because the pistons and rods are usually lighter than stock, so you need less to counterbalance.
Look, if keeping the mass close to centerline is the ideal you would see high end cranks with 3" crank throughs loaded with Mallory. Or better yet 2" or less loaded up with depleted uranium or some crazy dense material. But what you DO see is undercut throughs with thicker sections on their outside diameter.
