Harbor Freight Plastic Welder #1160314
01/18/12 06:33 PM
01/18/12 06:33 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Anyone ever use one of these? Heard they work pretty well???
http://www.harborfreight.com/plastic-wel...ment-96712.html
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Harbor Freight Plastic Welder [Re: 19cuda73] #1160315
01/18/12 08:47 PM
01/18/12 08:47 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
works great i have one.
just remember you can only plastic weld the same type filler and base materials.
cross type doesent work like pvc to pvdf etc
Greg
Re: Harbor Freight Plastic Welder [Re: HemiGreg] #1160316
01/18/12 09:57 PM
01/18/12 09:57 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I've got one that utilizes shop air. Controlling the airflow is key.
Takes practice, but a lot of the same principles as welding metal apply.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Harbor Freight Plastic Welder [Re: HemiGreg] #1160317
01/18/12 10:00 PM
01/18/12 10:00 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
If you intend to to do more than simple projects you will need way more than that. A real handheld welder is over 8x the price.http://www.leister.com/en/plastic-welding-product.html?catalog=1b301b71-fc43-4641-8ef0-506387c3ebfd&subcatalog=&product=85b8ba64-75a6-478d-90f4-599e3b8ec3a2
Re: Harbor Freight Plastic Welder [Re: Bill MeLater] #1160318
01/19/12 06:41 AM
01/19/12 06:41 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I bought one and it works well. Little learning curve on the heat application and yes, you have to be sure you id the types of plastic so you use the correct welding rod. It is amazing how it holds together as you would think the plastic has to puddle like steel welding but that is not the case. I do wish they made the rods black but I understand the logic of color coding the different types of plastic.
Driving modern convenience in classic beauty
Re: Harbor Freight Plastic Welder [Re: 19cuda73] #1160319
01/19/12 01:30 PM
01/19/12 01:30 PM
michigan
Sparky77 Offline
Sparky77  Offline
michigan
that looks really cool i think i need one of those .... where u get more rod???
LETS TAKE THIS #$^&&*#@ OUT AND SEE IF WE CAN GET IT TO DRIP PARTS
Sparky
72 CUDA 440 10.10 1/4
72 Challenger 340 Rallye..sunroof car
