Re: Electric Fuel Pump - 600 HP
[Re: tboomer]
#1159979
01/18/12 07:01 PM
01/18/12 07:01 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Thanks. Yes we do have them in stock. They are a phenomenal pump for what they are rated at. A true 110 and 140 GPH.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: BSB67]
#1159981
01/18/12 09:59 PM
01/18/12 09:59 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
So your cam does not have a fuel pump eccentric? You can get them on roller cams... FWIW...
383, Hemi 4-Speed, AlterKtion, D60
[Re: Lee446]
#1159984
01/19/12 01:11 AM
01/19/12 01:11 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Firecore or Mallory 140 if it were up to me...
The old standby Holleys do just fine..a hair more noise, but dang easy to rebuild.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Viol8r]
#1159987
01/19/12 11:20 PM
01/19/12 11:20 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
not cheap. but i have been running a external mounted aeromotive a1000 high pressure pump, step down regulator for a carb, and a variable voltage relay box for about 8 years and 50,000 trouble free miles. runs whisper quiet. pumps are good for 1000+ hp with a carb
perception is 90% of reality
