HV oil pump
#1159842
01/18/12 12:13 AM
01/18/12 12:13 AM
Posts: 583 San Antonio, TX
CurYellowBird
San Antonio, TX
Do you have to go to a deeper than stock oil pan if planning on going with a high volume oil pump in a 440?
What was the capacity of stock pans?
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
Re: HV oil pump
[Re: jcastle1]
#1159844
01/18/12 12:37 AM
01/18/12 12:37 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
I been driving my 73 340 Duster around for 6 yrs now with a HV oil pump...never has sucked the pan drive..LOL..
Even been down the drag strip a dozen times or so...did not suck the pan dry...LOL
has stock oil pan...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: HV oil pump
[Re: jcastle1]
#1159846
01/18/12 11:50 AM
01/18/12 11:50 AM
Challenger 1
Cincinnati, Ohio
Yes,you should.It will suck the pan dry in most cases. What's the application?
Most cases a HV oil pump is not needed and causes more harm than it does good.imo
Re: HV oil pump
[Re: Challenger 1]
#1159847
01/18/12 12:40 PM
01/18/12 12:40 PM
CurYellowBird
San Antonio, TX
The application is a 440, street driven, rare one or two trips to the strip. Biggest mods the motor will have is a basically a six pack bottom end with 906 heads, aluminum intake, EZ-EFI, and using the stock hi-po manifolds.
My old man thought that an HV pump should be put in every performance motor. Put one in my first car a couple years ago, 80' Malibu 350, and the cast crank at the end of the 3 years of use looked like it had been chewed up. Leads me to believe the stock 5 quart oil pan was pretty dry.
Project War Bird:
GY3 Curious yellow
All original
Re: HV oil pump
[Re: CurYellowBird]
#1159848
01/18/12 04:15 PM
01/18/12 04:15 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Ive run them for better than 40 years.Ran with stock and deep pans.Never any problems.I installed a bunch at work also on different vehicles.Never any problems.Rocky
Chrysler Firepower
Re: HV oil pump
[Re: CurYellowBird]
#1159849
01/18/12 04:41 PM
01/18/12 04:41 PM
Posts: 4,848 Memphis
HemiRick
Memphis
HV oil pump in an engine not built with loose clearances is just a waste of HP and needleesly heats up the oil.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: HV oil pump
[Re: Challenger 1]
#1159850
01/18/12 06:21 PM
01/18/12 06:21 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
I think one would have to factor in the overall build, but a HV pump is probably overkill more times than not.
Re: HV oil pump
[Re: CompSyn]
#1159851
01/18/12 08:24 PM
01/18/12 08:24 PM
A HV pump is fine on any build --if one eats enough HP to make you loose a race then then geeezzz!!! Eating HP is baloney! So what it may take one HP to drive that pump at 7k RPM Ok Ok two HP to drive it--that is bull for the average Joe on this board. Your dragging brake job is WAY bigger issue!!!!! Yea--turn 7000 RPM for a Bonneville mile and MAYBE the pan runs dry?? I have never seen evidence--Dan Cook Ran a 65 Dodge Hemi big inch with a stock 6 qt Hemi pan--wheels in the air--crazy 60 ft etc etc --A hundred guys on here would say Oh No that will not work!! IT DID! I have used stock pumps on some wicked BB race engines--I use HV on street engines because most folks think it is a plus--I have never seen an issue from either application--ever! They came about when Herb and others were turning 8K plus in four speed cars and they were looking for answers --the answer was get rid of the ten pound piston and rod combo of the day--so the HV was a band aid--one that has hung around forever--Melling makes em because they sell--not because we need them IMO
Re: HV oil pump
[Re: ]
#1159853
01/18/12 08:45 PM
01/18/12 08:45 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Some great comments here overall. In my case, going back way too many years, I was a somewhat regular bracket racer running a 426 wedge. I was having problems with spinning rod bearings. The typical scenario was just before running through the lights the engine would start to sound a bit sour, oil pressure would fall some and I'd push the clutch in right away to try and minimize the damage. I couldn't predict when it would happen; sometimes shortly after rebuilding the bottom end, other times it would run for months. I tried everything everyone told me; painted the valley of the block, loosened up on bearing clearances, chamfered oil holes, tufftrided crank, 6 quart pan, high volume pump, high pressure pump and was still seeing signs of bearing problems when I'd check the bottom end come fall. What finally cured the problem for me was putting an oil restrictor in the passages feeding the heads. An old top fuel guy told me to do that and it completely cured my problem. The fix cost me about $8.00. I'm a believer in running the bearings on the loose side and going with the high volume pump and at least one extra quart oil capacity.
Lead, follow or get the hell out of the way
Re: HV oil pump
[Re: BSB67]
#1159857
01/18/12 10:36 PM
01/18/12 10:36 PM
CompSyn
Pacific NW USA
I think you can go quit a bit faster than that w/ std pump and hemi pan. What are the 9 and 10 sec FAST guys using?
I wouldn't be surprised that the production high performance oiling system is quite a bit more bullet proof than typically given credit for.
Not sure what the FAST guys are using, Bod has raced in the PSMCDR class in the past.
