Hopefully my last 6 pack question #1159512
01/17/12 05:46 PM
01/17/12 05:46 PM
Finally a HUSKER again
Moparnut426 Offline OP
Ok, so Im rebuilding the center carb, first of all, the metering block to bowl gasket is not the same, close, but not perfect, second, these carbs were dirty carbs when I got them, and the metering block gasket is missing and I have nothing to compare that gasket to. What is the correct gasket for this carb? I cand read the directions, the print is VERY small, and blurry as hell. basically there is 3 gaskets to choose from, a black one, and 2 blue ones. 1 blue one has a cut out for the squirter hole in the carb body, I dont think thats the correct one as it will not seal to the hole on the metering block, the 3rd one has the squirter hole in it, but looks like the black one, but is missing 1 little hole up by the rectangle center hole.
Pretty damn confusing for a simple carb.
Kasey
Re: Hopefully my last 6 pack question [Re: Moparnut426] #1159513
01/17/12 06:14 PM
01/17/12 06:14 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
Holley 2300's? Here's the kit for them:
Holley # 3-396
How are things in NE?
dstryr, since 1986.
Re: Hopefully my last 6 pack question [Re: dstryr] #1159514
01/17/12 06:28 PM
01/17/12 06:28 PM
Thats the kit I have, and things are great. Healthy Family, and decent weather, Hows that Ioweeeeeeaaannnnn state treating ya?
Re: Hopefully my last 6 pack question [Re: Moparnut426] #1159515
01/17/12 06:34 PM
01/17/12 06:34 PM
IS THERE A CHANCE i HAVE THE WRONG MEETERING BLOCK ON THIS CENTER CARB?
Do they have a specific part number for the meetering block, The number on mine is 34r-7235b, I have a metering block off of my 4150 750 holley. Will it work? also this meetering block have the vacume tube port on the side, no tube inn it, but the port is open.
Kasey
Re: Hopefully my last 6 pack question [Re: Moparnut426] #1159516
01/17/12 07:21 PM
01/17/12 07:21 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a shot I took a while back for a thread when the Promax metering blocks just came out...Hopefully this helps...
Re: Hopefully my last 6 pack question [Re: Moparnut426] #1159517
01/17/12 07:21 PM
01/17/12 07:21 PM
I think it the wrong meetering plate, I have a meetering plate off a 750 4150 holey, and its a 5101 meetering plate. Im gonna run that one.
Kasey
Re: Hopefully my last 6 pack question [Re: screamindriver] #1159518
01/17/12 07:23 PM
01/17/12 07:23 PM
My front and rear carbs dont have any jets in them, is the one you pictured modified for the brass jets?
Re: Hopefully my last 6 pack question [Re: Moparnut426] #1159519
01/17/12 07:28 PM
01/17/12 07:28 PM
Harrisburg, Pa.
Harrisburg, Pa.
Yes disregard the outer carb pic..That was a pic of the Promax secondary metering plate...As is the black metering block...But the gasket should be what you need and the other metering block is an original 6-bbl piece for you to compare... I would'nt suggest mixing up the metering blocks...Let's just keep it simple and say they are different...
Re: Hopefully my last 6 pack question [Re: screamindriver] #1159520
01/17/12 07:45 PM
01/17/12 07:45 PM
So your saying Id better get a correct center meetering block?
Kasey
Re: Hopefully my last 6 pack question [Re: Moparnut426] #1159521
01/17/12 07:50 PM
01/17/12 07:50 PM
Harrisburg, Pa.
Harrisburg, Pa.
I don't have the metering block numbers in front of me at the moment...But off the top of my head I'm thinking you've listed a valid number for the center carb metering block...Does'nt it look like the one in my pic {other than the tube you need to add for the distributor vac advance} ??? What makes you think it's the wrong block ??? Just asking...
Re: Hopefully my last 6 pack question [Re: screamindriver] #1159522
01/17/12 07:54 PM
01/17/12 07:54 PM
because the gasket set I have wich is 3 of the same kit, none of the metering block to bowl gaskets fit my metering block. They all are wrong as far as slignment dowl spacing. Also have some alignment dowl broken off on the back side that align it to the carb body.
Kasey
Re: Hopefully my last 6 pack question [Re: screamindriver] #1159523
01/17/12 08:07 PM
01/17/12 08:07 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
70 440 metering block is stamped 6020,69 1/2 is 6170 and 340 is 6620.
And 4144,same as 6020.
Re: Hopefully my last 6 pack question [Re: Moparnut426] #1159524
01/17/12 08:07 PM
01/17/12 08:07 PM
Harrisburg, Pa.
Harrisburg, Pa.
Well there you have it...But the dowel would'nt be a deal breaker for use...Next question would be {to cover all the bases} did the block numbers get superseded with any new/repop units ???
Re: Hopefully my last 6 pack question [Re: screamindriver] #1159525
01/17/12 08:19 PM
01/17/12 08:19 PM
this metering block is stamped 7235, and there is a 7866
Re: Hopefully my last 6 pack question [Re: Moparnut426] #1159526
01/17/12 08:24 PM
01/17/12 08:24 PM
Harrisburg, Pa.
Harrisburg, Pa.
It's not looking good... Obviously not an original piece and could be the reason for a dowel alignment issue...Not what you want to hear but you may be looking for a replacement...
Re: Hopefully my last 6 pack question [Re: screamindriver] #1159527
01/17/12 09:57 PM
01/17/12 09:57 PM
Well The good thing is that this is not going on a numbers car, its going on a ramcharger, and I already spoke with the guy I bought the set up from, and he has other parts for me, so I just need to get with him.
Either way, Ill get things figured out,
Kasey
Re: Hopefully my last 6 pack question [Re: Moparnut426] #1159528
01/19/12 10:29 AM
01/19/12 10:29 AM
The metering block from my 750 stamped 5101 is warpped really bad, I forgot thats why I put billet blocks on my 750, so Ill scrap that idea, and go for a different metering block all together.
Thanks guys
Re: Hopefully my last 6 pack question [Re: Moparnut426] #1159529
01/19/12 01:44 PM
01/19/12 01:44 PM
Shoreline, Washington
72roadrunnergtx Offline
Here is the correct metering block to main body gasket for the 2300 series carb, blue non-stick version.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Hopefully my last 6 pack question [Re: 72roadrunnergtx] #1159530
01/19/12 03:43 PM
01/19/12 03:43 PM
Thats the one Im using, Thanks guys.
