470 Stroker numbers and estimates
#1158704
01/16/12 05:15 PM
01/16/12 05:15 PM
Posts: 322 San Diego, CA, United States
Texas_Charger
Alright guys, I've been putting together a build for the past few months and I was hoping some of y'all might be able to chime in on what kind of numbers I can expect. Here's the specs:
470 shortblock from Indy Cylinder Head (400 block/offset 440 crank) 10:1 compression Stealth heads CNC ported with a valve job hughes hydro/flat tappet cam: .592 int/.606 exh, 242* int dur/246* exh dur at .050, 108*lsa Crane 1.6:1 ductile rockers holley street dominator intake 1 7/8" primary full tube headers 2.5" dual exhaust with x-pipe
This build is going into a 1971 Charger, with a 727 auto, turbo action 2800-3000 converter, 3.91 8.75 sure-grip rear, and 275/60/15 rear tires.
Assuming I have and adequate fueling system and ignition system, what kind of horsepower/torque numbers and quarter mile times are y'all predicting?
1971 Dodge Charger SE 470/727/3.91 Suregrip 2016 Dodge Challenger Hellcat, 6-speed 1980 Pontiac Trans Am, Y84, WS6 2002 Ram 2500 Cummins/6-speed/2WD/QC 1971 Ford F-350 Ranger
Re: 470 Stroker numbers and estimates
[Re: Texas_Charger]
#1158707
01/16/12 10:26 PM
01/16/12 10:26 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I think it needs more converter....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: viperblue72]
#1158710
01/17/12 10:15 AM
01/17/12 10:15 AM
Texas_Charger
Thanks guys, I appreciate the input and advice. I've been stressing over the cam selection ever since I started looking at this build, and I did a ton of research before I finally made a decision. The general consensus that I came up with when choosing a hughes cam for a stroker motor was to go on hughes and pick out a cam that is suitable for a stock-stroke engine with the same combination and then go a size or two bigger, so that's what I did. Do y'all think it'll turn out to be under-cammed? As far as converter goes, this is going to be a 95% street car, with trips to the track made every now and then when I get the chance. Keeping that in mind, I didn't want to go too radical with the converter. Now for the carb... On the old 383 magnum in the car, with headers, intake, and a re-curved ignition I was running a re-jetted Quadrajet carb. Dad has a warmed-over 440 with a Q-jet and we've had really good luck getting decent power and great fuel mileage out of these carbs, plus they're really simple to tune. So for this engine, I'm gonna try and just re-jet the Q-jet and see what I've got. For primary jets I'm running a similar size to that found on a '70 RAM AIR 455 GTO, and for secondaries I have the next set up from what was found on a 500 Cadillac. If it turns out to be too lean I've always got more options on rods and jets, and plan B is an 800-850 holley. Thoughts? Thanks
[Re: Von]
#1158711
01/17/12 11:13 AM
01/17/12 11:13 AM
Posts: 3,149 Central NC
gch
Central NC
I ran the same stall on mine and it was fine for a street car.Lots of torque everywhere.Sure it would have E.T. a little better with more stall but would roast the tires at will.
Quadrajet will work but my 750HP holley made more power on the dyno than a regular 850dp.
I ran a q-jet from a 500 caddy on a 440 years ago and it moved plenty of fuel.
[Re: Texas_Charger]
#1158712
01/17/12 11:18 AM
01/17/12 11:18 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
I think that cam is just fine and well-matched to the rest of the combo. If you want any bigger you could opt for the Comp XE 251/257 @.050. Once you get over ~252 on a Hydraulic flat tap on the intake you're usually better off just going to a solid. The SD is a great manifold but maybe for your combo a performer RPM and square bore 800-850 may give you a tad more off idle/roll on torque. The Eddy avs 800 works very well and generally can get better cruise MPG than a holley, Q-jets can be magic if you know how to tune them, I had an awesome Brad urban Qjet on a 10.5:1 455 olds that I dropped in a 77 Caddy Seville sleeper many years back. I'd run a fairly tight 9 1/2" or 10" PTC or T/A converter, something that footbrakes to ~3000-3200 but tight enough not to feel at all slushy at part throttle in a heavy B body. Overall you have a very good, and well thought-outrecipie for a 535-550-ish horse pump gas motor. You didn't get hung up chasing high RPM power when what you really want is a ton of face distorting mid range torque, it's really what the 431-470 inch motors with standard sized ports do best, and they do it very well.
[Re: Streetwize]
#1158713
01/17/12 11:41 AM
01/17/12 11:41 AM
Texas_Charger
Thanks for the advice on cam and carbs. The reason I'm going with the SD intake is that I already had one on the 383, so I figured I could save a buck or two by just using that. Same with the carb. Thank you Streetwize for the kind words regarding the build... Being 21 years-old and on my first real solo build, its good to have some reassurance coming from someone with as much experience as y'all Just so y'all know, the build is just about complete and hopefully I'll get it running strong this weekend. Do y'all think 11's are out of the question?
[Re: 383man]
#1158715
01/17/12 12:58 PM
01/17/12 12:58 PM
Streetwize
Weddington, N.C.
With Drag Radials and decent weight transfer you should easily go 11.80's or maybe a little lower, first time out probably very low 12's. Start out shifting about 5600, tune for your plug readings and up the shift points 200 until it starts slowing down. Try to tune your launch as well as possible before going to the track, make sure you've got enough pump shot to pull you until the mains kick. One of the biggest issues tuning a heavy car. For a street car don't remove your sway bar but take as much preload out of the end links as you safely can without it being 'sloppy'. Lube the mounting bracket bushings with Lithium grease an make sure they don't bind. Make sure your rebound and jounce bumpers are all fresh and you have a good allignment on the car.
[Re: Streetwize]
#1158716
01/17/12 01:11 PM
01/17/12 01:11 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
With Drag Radials and decent weight transfer you should easily go 11.80's or maybe a little lower, first time out probably very low 12's. I agree,don't be dissapointed if it runs high 12's first time out. It takes a while to get a car sorted out. As far as estimates go,it should make around 530 hp and 560 tq when the tuning is all sorted out. Keith
[Re: Dunnuck Racing]
#1158717
01/17/12 02:52 PM
01/17/12 02:52 PM
Texas_Charger
As far as weight goes, I haven't been able to put it on a scale but here's some thoughts to ponder. Figures put a stock big block 1971 Charger at about 3900 lbs. I'm in the process of putting her on a diet, including: aluminum heads aluminum intake mini starter fiberglass hood lightweight front racing seats removing all the air conditioning components replaced heavy hidden headlights with lighter exposed units lightweight insulation headers (dont know if that saves any but cast iron manifolds sure are heavy) That's the start, I'd like to get it down around 3500 but I realize that's a pretty ambitious goal. The good news is my 135lbs wont contribute much to the race weight
[Re: Texas_Charger]
#1158718
01/17/12 04:59 PM
01/17/12 04:59 PM
Posts: 2,141 junction city oregon
viperblue72
It should go mid 11s. Also your cam is just fine. I thought I read challenger but its a charger. Focusing on torque is gonna be very helpful. I wouldn't change anything at the point you're at. Just get it together and go from there. For carburetion my favorite carb has always been a holley 750hp. But different people have different preferences.
