Page 3 of 3 1 2 3
Re: trans fluid for A-518 [Re: hp383] #1158699
01/19/12 06:35 PM
01/19/12 06:35 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
In my opinion it was no fluke, alot of the diesel guys run hydraulic fluid in there transmissions, i believe the most popular is the john deere hygard. I guess i will use regular dexron/merconIII. with a shift kit the dexron should be ok, and since it has better lubricating ability over type f and its what my builder said to run then i will run it, i was just wanting to run type f for some firmer shifts is all and its a little cheaper, but i used dexron/merconIII in the 727 that was in my 76 dodge powerwagon and i never had any problems with that transmission. When i first got that 76 the 318 that was in was worn out and tired, burned oil had no power no compression. So i figured the transmission was probly a little tired as well, when i first got it i flushed all the fluid out of it changed the filter and put new dexron/merconIII in it along with a bottle of lucas transmission fix and i never had any problems with that transmission, i serviced it once a year and it ran untill the day i rolled the truck, never once had a transmission issue with it and i was running dexron/merconIII so it cant be that bad of a fluid.
Re: trans fluid for A-518 [Re: pjc360] #1158700
01/19/12 08:41 PM
01/19/12 08:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
So, Mr.kunkel, does type fa have better lubricating ability over regular type f?
FA is just an improved version of the same old type F, still not what you want in an OD transmission.
Re: trans fluid for A-518 [Re: John_Kunkel] #1158701
01/19/12 09:18 PM
01/19/12 09:18 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
dexron/merconIII it is i guess then, at least it meets in the middle between type f and atf+4. i have had good luck with dexronIII in the past too.
Re: trans fluid for A-518 [Re: pjc360] #1158702
01/19/12 09:20 PM
01/19/12 09:20 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
do you have a personal prefernce as of wich brand of dexron/merconIII to run mr kunkel or will the valvoline dexron/mercon work fine? because thats what i was planning on using, ether that or the napa house brand dexron/merconIII
Re: trans fluid for A-518 [Re: pjc360] #1158703
01/20/12 03:38 PM
01/20/12 03:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I use the house brand of whichever store I'm in.
Page 3 of 3 1 2 3
