Superbird vacume lights detail? #1158521
01/16/12 12:06 PM
01/16/12 12:06 PM
Nashville, TN
MOPARMIKE69 Offline OP
Nashville, TN
Anyone have a service manual detail of the vacume diagram for the Superbirds lights? I have never worked on one and I am going over this afternoon to help a friend fix his. They remain in the open postion even after the car is shut off.
I am guessing it is either the headlight vacume motor or the switch but it sure would make the process go quicker if I had a diagram. I do not have a service manual for the 70 plymouth. I have 68 and 69 but not 70.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Superbird vacume lights detail? [Re: MOPARMIKE69] #1158522
01/16/12 03:03 PM
01/16/12 03:03 PM
SE Pa.
LimeliteAero Offline
SE Pa.
I cant supply you with anything to view but I can tell you the lights are not opened/closed with a motor. They work off manifold vacuum that keeps them closed while the engine is running and a reserve can that holds vacuum to keep them closed while the engine is off(located under the battery tray). If they close while the car is running but creep up when the engine is off then you have a vacuum leak.
I would start under the dash and look for issues with the vacuum tubing all the way up to the headlight door acutuators.
Sorry about not having any documnets. The information your looking for is not in the FSM anyway. You will need the Superbird supplemental that has all the specific parts and even then it wont tell you about any functioning troubleshooting. My book is at the shop working on my car.
Re: Superbird vacume lights detail? [Re: MOPARMIKE69] #1158523
01/16/12 03:20 PM
01/16/12 03:20 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Not from FSM, but...
Re: Superbird vacume lights detail? [Re: xs29j8] #1158524
01/16/12 03:26 PM
01/16/12 03:26 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Should be the same as 68/69 Charger...
Re: Superbird vacume lights detail? [Re: xs29j8] #1158525
01/17/12 10:24 AM
01/17/12 10:24 AM
Nashville, TN
Nashville, TN
Thanks to all for the help. I got them working with replacing some of the hoses. They still have a slow, slow slow leak down after shutting off the car. I will be checking the canister next but I am afraid it is the switch since it is so slow.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Superbird vacume lights detail? [Re: MOPARMIKE69] #1158526
01/17/12 11:21 AM
01/17/12 11:21 AM
SE Pa.
SE Pa.
make sure to put some grease where the hoses connect to the back of the switch, it'll help with sealing issues between the plastic switch and the rubber hoses.
Re: Superbird vacume lights detail? [Re: MOPARMIKE69] #1158527
01/17/12 11:26 AM
01/17/12 11:26 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If they leak down and the hoses and diaphragm in the actuators are good your problem is with the vacuum switch attached to the headlight switch.The grease in the switch dries up,in the summer mine stay shut for months,in the winter about two weeks and they start to open.
Re: Superbird vacume lights detail? [Re: 62maxwgn] #1158528
01/17/12 04:00 PM
01/17/12 04:00 PM
My hovercraft is full of eels
DaveKanofsky Offline
Those of us who cheat take the spring off of the side of the headlight pod. The spring is a failsafe. The headlight will work fine without them, and stay closed all of the time.
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: Superbird vacume lights detail? [Re: DaveKanofsky] #1158529
01/18/12 03:27 PM
01/18/12 03:27 PM
SE Pa.
SE Pa.
I "cheated" and removed my springs, so I wont be doing the "sleepy eye shuffle" once I get things back together.
