Reusing Cometics #1158491
01/16/12 10:35 AM
01/16/12 10:35 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
If your going to reuse Cometics, should you resurface your aluminum heads or is that not necessary?
Anyone had issue trying to reuse Cometics?
I don't feel any grooves or indention in the heads caused from the Cometics so I guess it just flatens out the raised sealing rings on the Cometics (I was mistakingly thinking it would leave grooves in the heads like when you O-ring the block).
I've got both of my motors apart (Abbey's and mine), her Cometics are new from last year. Mine are about 3 years old.
Not sure I really want to take a chance but considering it so I wanted to get some opinions from you guys.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Reusing Cometics [Re: WadeMetzinger] #1158492
01/16/12 11:10 AM
01/16/12 11:10 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Just clean the gaskets and heads and bolt it back together......
If you can't handle the truth, you're living a lie.......
Re: Reusing Cometics [Re: Big Squeeze] #1158493
01/16/12 11:23 AM
01/16/12 11:23 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
and make sure they go back on with the same orientation that they came off. I'm on my 3rd reuse. No spray copper or any sealers, just bolted on
I like the ability reuse gaskets and that's why I chose the materials that I use to make my gaskets with
Re: Reusing Cometics [Re: roadhazard] #1158494
01/16/12 12:47 PM
01/16/12 12:47 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I spray mine with copper but I have reused a set 4 times at over 12:1 compression on alcohol
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Reusing Cometics [Re: Irun5snd8th] #1158495
01/16/12 01:26 PM
01/16/12 01:26 PM
Mo.
racerx Offline
racerx  Offline
Mo.
y the copper spray just curious?
Re: Reusing Cometics [Re: WadeMetzinger] #1158496
01/16/12 01:43 PM
01/16/12 01:43 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I reuse them 3 times. Clean the block/heads and the surface of the gasket. Some people drill out the rivets and clean between the individual gaskets but I do not. I wipe them down with thinner which removes what's left of the factory rubber coating, then give them a light spray with copper gasket sealer to seal the water passages and back on they go.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Reusing Cometics [Re: Big Squeeze] #1158497
01/16/12 02:39 PM
01/16/12 02:39 PM
tn
robnbird Offline
robnbird  Offline
tn
do not use a cleaner like carburetor cleaner to clean the gasket. most gaskets have a very thin layer of silicon on the outer surface of the gaskets and some cleaners will wrinkle the sealer.
Re: Reusing Cometics [Re: WadeMetzinger] #1158498
01/16/12 02:58 PM
01/16/12 02:58 PM
I have reused then several times, with (on customers motors that wanted them sprayed with Copper Coat and Hylomar) and without spraying sealer on them . I don't use any sealer on them on my own motors As already said keep them pointed up on the same side they came off of and go for it
Re: Reusing Cometics [Re: WadeMetzinger] #1158499
01/16/12 03:36 PM
01/16/12 03:36 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hello,
anyone want to buy a set for .060 over 440 .049 thick, i will not reused them.
pm me
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Reusing Cometics [Re: 440lebaron] #1158500
01/16/12 04:35 PM
01/16/12 04:35 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
hello,
pm me
gary
Sure......do "your" heads and block come with them
Re: Reusing Cometics [Re: roadhazard] #1158501
01/16/12 05:37 PM
01/16/12 05:37 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
You make head gaskets?
Re: Reusing Cometics [Re: racerx] #1158502
01/16/12 05:43 PM
01/16/12 05:43 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
My deck surface does not meet the smoothness criteria for the gasket. If I dont use the copper they seep water to the outside. That and I wouldnt chance it anyway. Too much trouble to take back apart to save myself 5 minutes of spraying.
Re: Reusing Cometics [Re: POS Dakota] #1158503
01/16/12 06:20 PM
01/16/12 06:20 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
No Sir,
Just the soft gaskets like valve cover, intake, oil pan, timing cover, etc, etc.
Re: Reusing Cometics [Re: Irun5snd8th] #1158504
01/17/12 12:10 PM
01/17/12 12:10 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I understand now Thax.......
Re: Reusing Cometics [Re: racerx] #1158505
01/17/12 02:23 PM
01/17/12 02:23 PM
Penna
70satelliteguy Offline
Penna
Just to let everyone know, I usually use my Cometics several times without issues,spraying them with coppercoat just as insurance.
This year after 3 uses I decided to replace them just as a regular part of my refreshening my motor. I ordered the Mr. Gasket ones which are supposed to be just repackaged Cometics.
The packaging specifically say's to "NOT COAT the gaskets,just clean and bolt on. I decided that I was gona spray them anyway cuz I always do!!!
I don't know if they just changed things or what but the surface of the gaskets are now kind of shiny and will not accept a spray of coppercoat. After drying it easily comes off even with gentle handling!(I did clean them first)
So I installed them with out any coppercoat this year for the first time and will keep my fingers crossed and hope for the best.
Mike
Re: Reusing Cometics [Re: 70satelliteguy] #1158506
01/17/12 03:00 PM
01/17/12 03:00 PM
an8sec70cuda Offline
The Cometics also say not to use any coating/spray on them, but myself and everyone I know spray them w/ coppercoat.
CHIP
'06 GMC 2500HD LBZ Duramax
