My NOS trim rings will not fit my wheels.....help #1158025
01/15/12 05:14 PM
01/15/12 05:14 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
I just spent two hrs trying to put a ring on a wheel. I'm trying to put an NOS 14" trim ring on an original 14"X 5.5" PN 2944252 wheel. I get the ring to go on 2/3 of the way then I can't go any further. What I think is happening is the inner part of the ring, where the springy part is spot welded is too large. I noticed there is a gap on all the rings, but I would think if they would of closed the gap before welding that would make the cicumference smaller.
I measured the cicumference and it measures 44".
Has anyone had trouble with these, can anyone who has an 14" ring measure that area around.
Any help would be gratly appreciated. Can you break the welds, close it, and re-weld without damaging the ring.
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158026
01/15/12 10:54 PM
01/15/12 10:54 PM
Ont, Canada
Ont, Canada
I'm just thinking, maybe this isn't a mopar trim ring. Anyone can tell me what to look for?
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158027
01/16/12 12:01 AM
01/16/12 12:01 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So a picture of the front face showing the outside edge.
Did the come in Mopar NOS boxes with part numbers on them?
Re: My NOS trim rings will not fit my wheels.....help [Re: autoxcuda] #1158028
01/16/12 12:17 AM
01/16/12 12:17 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here are a couple pics of a correct '70 & up 14" trim ring. I'd guess a NOS trim ring would be a bit tough to install the first time around.
Re: My NOS trim rings will not fit my wheels.....help [Re: autoxcuda] #1158029
01/16/12 12:48 AM
01/16/12 12:48 AM
Ont, Canada
Ont, Canada
I will get a picture of the front face tomorrow and yes they were in a mopar box, part number ended with 424, again I will verify and post as they are in the garage.
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158030
01/16/12 12:23 PM
01/16/12 12:23 PM
Ont, Canada
Ont, Canada
Here's a picture of the front face
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158031
01/16/12 12:23 PM
01/16/12 12:23 PM
Ont, Canada
Ont, Canada
Another of the face
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158032
01/16/12 12:25 PM
01/16/12 12:25 PM
Ont, Canada
Ont, Canada
Now I measured the diameter of the inside part of the ring as shown, it is 13 15/16"
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158033
01/16/12 12:32 PM
01/16/12 12:32 PM
Ont, Canada
Ont, Canada
Then I measured the inside part on the rim which that part would fit in, it measures 13 3/4". It is out 3/16". From the scratches on the paint from trying to install it is also telling me that it is bottoming out on that part and won't go down any further.
First can someone confirm it is in fact a mopar ring. I attached the package that it came in but that does not guarantee anything.
Has anyone ever encounterd this? These ring were manufactured in 2002 according to the sticker. I keep on coming back to that gap in my first picture.
Any insight would be great. If they are the correct rings then I'm tempted to grind those spot welds, that will give it some room to squeeze but I'm not sure what that will do to its ability to hold on without rewelding them.
Any suggestions???
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158034
01/16/12 12:35 PM
01/16/12 12:35 PM
Ont, Canada
Ont, Canada
Oh, the other piece of information is that the ring measures 2" to the bottom of the fron lip when on a flat surface
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158035
01/16/12 01:49 PM
01/16/12 01:49 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I recall someone else on here having a problem with the new mopar trim rings. Something about the way they were welded and the length of the clips. try here https://board.moparts.org/ubbthreads/showflat.php?Number=6672585
Re: My NOS trim rings will not fit my wheels.....help [Re: mopars4ever] #1158036
01/16/12 02:43 PM
01/16/12 02:43 PM
Ont, Canada
Ont, Canada
Hey thanks for finding that, that is exactly the same issue I have. I bought these rings many years ago, just installing them now. I believe the circumference is too big, not welded properly.
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158037
01/16/12 03:46 PM
01/16/12 03:46 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Same problem I had. Even if you do get them on, they will wobble when you spin the wheel since that spot weld is crooked and will hold the trim ring farther from the wheel at that spot. Also, look how the mounting ring is covering part of your valvestem hole. These are Mopar rings but they had production problems on the later ones.
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158038
01/16/12 04:15 PM
01/16/12 04:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I guess this kinda puts the whole reproduction parts not fitting issue in perspective... If Chrysler can't make these parts fit why should smaller companies...
Re: My NOS trim rings will not fit my wheels.....help [Re: 1_WILD_RT] #1158039
01/16/12 05:31 PM
01/16/12 05:31 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
They look pretty wide for a 5.5 wheel though, maybe they need a 14x6?
Re: My NOS trim rings will not fit my wheels.....help [Re: 1_WILD_RT] #1158040
01/16/12 05:39 PM
01/16/12 05:39 PM
Ont, Canada
Ont, Canada
Spent some time today on this again, and what I see is part A on the trim ring is bottoming out on the rim because the circumference is too big. Now to figure out how to make it smaller. Could break the weld and that would give the ring someplace to shrink when you hammer on it or cut out a V every so often to give that part of the ring some flex. See pic next one down
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158041
01/16/12 05:41 PM
01/16/12 05:41 PM
Ont, Canada
Ont, Canada
This is where I would cut some V
What do you guys think?
Re: My NOS trim rings will not fit my wheels.....help [Re: Steve340] #1158042
01/16/12 11:08 PM
01/16/12 11:08 PM
Edmonton, Alberta, Canada
Dartman75 Offline
Dartman75  Offline
Ditto for mine. Early 2000's never fit properly, never did try to resolve the fit...
Re: My NOS trim rings will not fit my wheels.....help [Re: Dartman75] #1158043
01/17/12 02:00 PM
01/17/12 02:00 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I would think there is a fine line with cutting not enough or cutting too much. Too much and they will probably come off while driving.
Re: My NOS trim rings will not fit my wheels.....help [Re: gygeneral] #1158044
01/17/12 10:36 PM
01/17/12 10:36 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Same story here. Back in 2000 I bought 4 of that same part# from the local Chrysler dealer for my Swinger 340 that was being restored. In 2002 when I went to install them... very poor fit!!
It was the lesser of two evils, in spite of the poor fit they still looked better than the old banged up ones.
I would appreciate if you would post how/if you fix them. Even after 10 years I may try to fix them if you have success.
