dual carbs: eddy 1406's or OE 60's 4131 AFB's
#1157858
01/15/12 02:49 PM
01/15/12 02:49 PM
RapidRobert
Have both sets avail to be refurbished. Which set would you guys recommend I go w? 451 big block DD w mild cam. more interested in mileage/driveability than HP potential. Thank you for your time.
Re: dual carbs: eddy 1406's or OE 60's 4131 AFB's
[Re: ScottSmith_Harms]
#1157862
01/15/12 03:30 PM
01/15/12 03:30 PM
RapidRobert
Scott good to hear from you. I went to the site you sent & they want over $200 canadian for the rebushing kit & iirc it has 8 bushings. You and a local guy who does them said it is a rarity to have to do them but these are LOOSE but that's MY subjective assessment. I should grab a dial indicator & shoot you a dimention. he's going to do em for $25 a shaft so I might have him do all 4 shafts (anal I know but they SEEM too loose) and I want good mileage/driveability and dont want to have to go back inside again
#1157864
01/15/12 03:56 PM
01/15/12 03:56 PM
RapidRobert
The eddy's being newer I'd assume they are OK but the 4131's are loose but yes I should have listened to the 2 experts (you being one of them) who said leave them alone
[Re: RUNCHARGER]
#1157866
01/15/12 06:10 PM
01/15/12 06:10 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Does the 4131 have the vacuum controlled secondary air door? I know I bought a bunch of old AFB's to make hemi clones and one of them did not have an air door, can't remember if it was the 4131 or not. If no air door I wouldn't monkey with it.
Sheldon
No secondary air valve on the 4131.
#1157868
01/15/12 06:47 PM
01/15/12 06:47 PM
RapidRobert
here's one of em. The rebusher has the other one
