Small crack in my 426 block, Should I worry?? #1157759
01/15/12 01:43 PM
01/15/12 01:43 PM
Wattsburg, Pa
Dr V Offline OP
Dr V  Offline OP
Wattsburg, Pa
Hello all, i developed a bit of a lump in my throat yesterday after torquing my heads back onto my freshly rebuilt 69 426. Long story short I didnt port and flow the heads when I had the motor built. Call it a dumb decision. Anyways, I had them done, I followed the torque pattern given by my builder. At the end of the last round of 70 ft lbs I noticed a small crack in the block where the stud from the head mounts. The stud looks a little crooked but nothing was stripped, just a little off center. Everything else is tight and looks great. Im definitely no engine builder (tooth mechanic is my specialty), so I figured I would ask the experts. The crack is about 1/4 inch long above the nut and washer. I am calling my builder tmrw too. Thanks
69 1/2 A12 BEE 4 spd
1968 Charger 383
1970 Roadrunner 440+6 Survivor
2019 Redeye
2005 FORD GT Red/White
2017 Viper ACR Extreme Red/White
1979 Branco Red/Red
2018 Porsche GT3 Miami
1971 440+6 Cuda 4 speed V2
2020 Sebring Orange Vette
1979 Chevy Boogie Hippie Van
Re: Small crack in my 426 block, Should I worry?? [Re: Dr V] #1157760
01/15/12 01:49 PM
01/15/12 01:49 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I only torque those to 35. It looks like it will split all the way up. I'd be tempted to pull the head and drill a hole at the end of the crack before it runs further. Then keep an eye on it.
Sheldon
Re: Small crack in my 426 block, Should I worry?? [Re: RUNCHARGER] #1157761
01/15/12 02:07 PM
01/15/12 02:07 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
If it were mine I would pull it apart and fix it while it can still be fixed. I am almost positive it will only get worse,I have been a welder for 25+ plus years. But 1st wait and see what some of the others have to say,I am sure you are not the only one to ever have this happen. I hope they all tell you its fine leave it along nothing to worry about,but best to 1st make sure.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Small crack in my 426 block, Should I worry?? [Re: MRMOPAR622] #1157762
01/15/12 02:40 PM
01/15/12 02:40 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Another way to look at things is its already torque down,if the heat does not open the crank wider no problem. Take and drill a small hole at the base of the crack not all the way through,put you some paper towels around the bottom and clean the area with brake cleaner and put a coat or 2 of JB-Weld starting about 1 1/2"-2" on each side of it. Not a big fan of JB-Weld but in this case it might work. At this point your only other option is to pull it apart and weld it or leave it along & just maybe the JB-Weld will give it enough strength to hold.
Re: Small crack in my 426 block, Should I worry?? [Re: MRMOPAR622] #1157763
01/15/12 02:50 PM
01/15/12 02:50 PM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Take it apart and fix it. It's a pain, but, better than if it does crack more. Could be carnage if a piece broke and fell off,,, which probably won't hapen... but... is it worth the chance?
Chris from New Jersey
Re: Small crack in my 426 block, Should I worry?? [Re: fig426] #1157764
01/15/12 04:57 PM
01/15/12 04:57 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Pop the head now and repair.It's an easy weld and not a super critical location.If you don't fix it now,every time you hit the loud pedal,you will be thinking about that crack
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Small crack in my 426 block, Should I worry?? [Re: hemi-itis] #1157765
01/15/12 05:20 PM
01/15/12 05:20 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
uh yep, I fully agree.
Re: Small crack in my 426 block, Should I worry?? [Re: hemi-itis] #1157766
01/15/12 05:24 PM
01/15/12 05:24 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
+2
They never fix them selves. And the results could be very very bad.
Edited to add........... are we working on the forth owner - high mileage piece of junk that we drove in high school ? ( Well.......I did anyway ) or a nice car that is capable of providing hours of fun and entertainment ?
My daily driver , I don't care so much.
My baby ? I care a lot.
Re: Small crack in my 426 block, Should I worry?? [Re: tubtar] #1157767
01/15/12 07:00 PM
01/15/12 07:00 PM
Wattsburg, Pa
Dr V Offline OP
Dr V  Offline OP
Wattsburg, Pa
Thats what I thought the best plan would be. Im pulling the head tonight. Will it take a conventional weld? My Dad has all of that stuff at his auto parts store, but neither of us has done this before...
1968 Charger 383
2019 Redeye
1979 Branco Red/Red
Re: Small crack in my 426 block, Should I worry?? [Re: Dr V] #1157768
01/15/12 07:20 PM
01/15/12 07:20 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i'd take it to someone who knows how to weld cast iron. just do as others mentioned, drill a small hole to stop the crack. don't over torque the bolt & u will be fine. seeya.
Re: Small crack in my 426 block, Should I worry?? [Re: rickraw] #1157769
01/15/12 07:39 PM
01/15/12 07:39 PM
RUNCHARGER Offline
RUNCHARGER  Offline
If you want to weld it, I think it should be disassembled, repaired by a pro and then the adjoining bores checked for roundness and the deck checked for flatness. Thats why I would just drill a hole in the end of the crack and watch it. Cast iron welding near machined surfaces is not a backyard operation. JMO.
Sheldon
Re: Small crack in my 426 block, Should I worry?? [Re: RUNCHARGER] #1157770
01/15/12 08:06 PM
01/15/12 08:06 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Am I the only one that it seems to look like this boss has been repaired before, seems like there evidence of welding slag/inclusions, and the welded area was then ground smooth. If this is the case its to me means a bad repair, and will only get worse. Are there others with the same look, but not cracked?
Re: Small crack in my 426 block, Should I worry?? [Re: jcc] #1157771
01/15/12 08:17 PM
01/15/12 08:17 PM
RUNCHARGER Offline
RUNCHARGER  Offline
It does look worked. But it's hard to tell with these old castings and there is grinding on the valley possibly to aid oil drainback.
Sheldon
Re: Small crack in my 426 block, Should I worry?? [Re: RUNCHARGER] #1157772
01/15/12 08:23 PM
01/15/12 08:23 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Actually I looked at the pic again, and there also looks like a color change, like nickel, which is a preferred CI rod filler for welding. I can't see why for oil drain back one would grind on a under load mounting boss, but not grind the area right next to it.
Re: Small crack in my 426 block, Should I worry?? [Re: jcc] #1157773
01/15/12 08:24 PM
01/15/12 08:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There has been a lot of grinding in that area , are the other head bolt bosses ground on like that? If not that one has definitely been worked before and as said it's only going to get worse.
Re: Small crack in my 426 block, Should I worry?? [Re: JohnRR] #1157774
01/15/12 09:23 PM
01/15/12 09:23 PM
Wattsburg, Pa
Dr V Offline OP
Dr V  Offline OP
Wattsburg, Pa
Now that I looked at the other 7 some have a little bit of grinding on them. But.... This one in particular is exceptionally thin on the wall that cracked. I would bet that it has been touched before. My engine guy said that it was put together with mismatched parts and was pretty poorly assembled when he first cracked into it. Typical Barrett Jackson car, slap it together and get it to Scottsdale. LOL I will ask my guy tomorrow who the best to weld cast iron is in our area. I really dont want to remove the motor at all!!!
1968 Charger 383
2019 Redeye
1979 Branco Red/Red
Re: Small crack in my 426 block, Should I worry?? [Re: Dr V] #1157775
01/15/12 09:28 PM
01/15/12 09:28 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
DO IT RIGHT WHATEVER IT TAKES
home of the
Sox and Martin Hemi Duster
Re: Small crack in my 426 block, Should I worry?? [Re: Dr V] #1157776
01/16/12 01:22 AM
01/16/12 01:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You aren't going to fix it properly if that is the case .
Re: Small crack in my 426 block, Should I worry?? [Re: JohnRR] #1157777
01/16/12 11:27 AM
01/16/12 11:27 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Could be that you can leave it, if it is thin there it would crack again after welding. If it is not cracked on the other side, and thicker there, maybe there is enough support already. I assume you have run without problems untill you saw the crack.... Worst will be that the crack is inside the boss,behind the nut. That could also happen if you start welding on this thing. My
Re: Small crack in my 426 block, Should I worry?? [Re: Oyvind Mopar] #1157778
01/16/12 12:21 PM
01/16/12 12:21 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
i see your in the penn. area. get ahold of bob george as he knows his way around welders and 426s. dave
