8 1/4" axle vent tube? #1157471
01/14/12 10:16 PM
01/14/12 10:16 PM
Lemont, IL
Not_A_Blazer Offline OP
super gas
super gas
Lemont, IL
I have a 8.25 that was originally in a '79 Cordoba,that I'm putting in another application. There is a hole on the top,to the passenger side of the differential that I assume was for a vent tube. Does anyone have a picture of what it looked like,or know what other vehicles I can find one on (dakota,5th ave,etc.)
Re: 8 1/4" axle vent tube? [Re: Not_A_Blazer] #1157472
01/15/12 01:02 AM
01/15/12 01:02 AM
md
mopars4ever Offline
mopars4ever  Offline
md
the hole is where the brake hose mounts, the vent is on the other side
Re: 8 1/4" axle vent tube? [Re: mopars4ever] #1157473
01/15/12 01:04 AM
01/15/12 01:04 AM
md
mopars4ever Offline
mopars4ever  Offline
md
vent
Re: 8 1/4" axle vent tube? [Re: mopars4ever] #1157474
01/15/12 04:22 PM
01/15/12 04:22 PM
Lemont, IL
super gas
super gas
Lemont, IL
The brake hose mounts on the driver's side axle tube,and just has a regular bolt holding it down.
I was thinking of just plugging the open hole,and finding a bolt that is hollow,and holds down the brake hose as well,like my '87 Ram had.
Re: 8 1/4" axle vent tube? [Re: Not_A_Blazer] #1157475
01/16/12 04:59 PM
01/16/12 04:59 PM
md
mopars4ever Offline
mopars4ever  Offline
md
This is a rear out of a 79 volare. It should be the same setup. The hose is held on by a bolt. How about posting a pic? Makes it easier then guessing at it.
Re: 8 1/4" axle vent tube? [Re: Not_A_Blazer] #1157476
01/16/12 08:12 PM
01/16/12 08:12 PM
scratchnfotraction Offline
your wanting a vent/brakeline tee bolt like 8 3/4s use. if I understand what you asking.
I think you could convert that over with the 3-port brass block/vent bolt from a 8 3/4.
you may have to change the rubber line from the frame hard line to the brass block port.
i will see if I can dig up the line/block vent bolt i have for pics.
after re-reading..i think you just need the vent bolt from an 8 3/4
Re: 8 1/4" axle vent tube? [Re: scratchnfotraction] #1157477
01/16/12 09:32 PM
01/16/12 09:32 PM
like this one?
Re: 8 1/4" axle vent tube? [Re: scratchnfotraction] #1157478
01/16/12 09:33 PM
01/16/12 09:33 PM
Re: 8 1/4" axle vent tube? [Re: scratchnfotraction] #1157479
01/16/12 09:35 PM
01/16/12 09:35 PM
Re: 8 1/4" axle vent tube? [Re: scratchnfotraction] #1157480
01/28/12 10:53 PM
01/28/12 10:53 PM
Lemont, IL
super gas
super gas
Lemont, IL
Thanks for the pics,I ended up going to the shed and the '55 stock rear that I took out of the truck had the same style vent tube,and was also the same pipe thread!
