Re: Fire Bottle Refill
[Re: Plumb Wired]
#1157407
01/17/12 01:49 PM
01/17/12 01:49 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
I need to get one filled as well and have not checked on a source to do so yet. We performance tested ours at the Street Car Supernationals. Left a nasty burn on my ankle too..
So if there is info out there please fill me in. FWIW mine is Halon.
[Re: Al_Alguire]
#1157408
01/17/12 02:30 PM
01/17/12 02:30 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
We are Cold Fire Distributors, Cold Fire is a water/foam based product. Halon is being phased out and replaced by FE36. A local fire suppression company may be able to fill your bottle depending on the valve. It would be best to send it back to the manufacturer. Keep in mind fire bottles are SFI approved and are only good for six years and at that point they are supposed to be taken out of service. They are also supposed to be recertified every two years and can only be refilled six times during their six year life span per SFI 17.1 section 2.7. Also something that is overlooked is the fact that NHRA, IHRA & ADRL require (stainless) steel tubing when a lot of the systems sold come with aluminum tubing. Mike Gray
[Re: Plumb Wired]
#1157409
01/17/12 02:36 PM
01/17/12 02:36 PM
Plumb Wired
Blue Ridge, VA
Cold Fire Bottles can be recharged by Cold Fire Southeast, Pelham, AL or DJ Safety, Los Angeles, CA. Cold fire is a unique product you won't find at your local fire suppression company.
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#1157411
01/19/12 05:31 AM
01/19/12 05:31 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Mike Gray
at what point is that SFI section required? ET/MPH?? I have a halon system for my 11 sec car with aluminum tubing....it's obviously not required at my mid 11's though.
