'72 RR engine bay fender to cowl bars, do I need them? #1157397
01/14/12 08:39 PM
01/14/12 08:39 PM
Western., NY
sco440 Offline OP
sco440  Offline OP
Western., NY
First off I don't know their proper name and have only seen them on 1 '72 RR. They both bolt to a stud near the wiper motor and the other ends go diagonally to the fender bolts on either side. Questions.
1. Are they only on 72's
2. Are they body color or black, (i have only seen black)
3. What is their purpose?
4. Do I need them or can I leave them off
'72 Road Runner
'72 Dart Swinger 340
'12 Challenger R/T
Re: '72 RR engine bay fender to cowl bars, do I need them? [Re: sco440] #1157398
01/14/12 08:42 PM
01/14/12 08:42 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
the factory put them on ,so i quess they are supports for the fenders,do you need them?i took mine off with no ill effects.
Re: '72 RR engine bay fender to cowl bars, do I need them? [Re: sco440] #1157399
01/14/12 08:44 PM
01/14/12 08:44 PM
Kirkland, Washington
Pacnorthcuda Offline
They stiffen up the front clip considerably. Reduce fender wobble. F-bodys had them too--body color.
Re: '72 RR engine bay fender to cowl bars, do I need them? [Re: sco440] #1157400
01/14/12 08:45 PM
01/14/12 08:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
My 74 has them as well. I guess they were there to tie the fenders to the cowl for some extra rigidity. As to how much different they really make, probably not that much. They can't control any flex side to side, just fore and aft along their length.
Re: '72 RR engine bay fender to cowl bars, do I need them? [Re: sco440] #1157401
01/14/12 10:21 PM
01/14/12 10:21 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
72-up
black
Reduce fender shake at speed
They do make a difference. Factory added them for a reason. The shake is an issue on previous generation cars too.
That being said, they were deleted on N96 cars due to clearance to the air box. That's a 72-only issue. A lot of guys put them on anyway, including the PO of my car.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: '72 RR engine bay fender to cowl bars, do I need them? [Re: 471Magnum] #1157402
01/14/12 10:27 PM
01/14/12 10:27 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Oh... they also come in real handy for tying up your headers with bungee cords while you're pulling the heads, changing the starter, pulling the transmission, or any other repair work that requires detaching the headers. DAMHIK.
-Jim
Re: '72 RR engine bay fender to cowl bars, do I need them? [Re: 471Magnum] #1157403
01/15/12 01:07 AM
01/15/12 01:07 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Also the 72's are different than the 73/4 ones
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
