wiper motor #1157205
01/14/12 04:00 PM
01/14/12 04:00 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Is there spacers between the motor and firewall, I installed mine and when i tested it witha remote battery , the main drive link rod was tight to the bottom of the cowl opening, it moved a bit but jamed when it made contact there ? Thanks
Re: wiper motor [Re: 300_dup5] #1157206
01/14/12 04:49 PM
01/14/12 04:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what car? there are rubber bushings/spacers that fit into the mounting holes in the wiper base...........
Re: wiper motor [Re: mikemee1331] #1157207
01/14/12 05:23 PM
01/14/12 05:23 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
70 cuda. I took this apart 4 years ago, and just had the motor rebuilt, drive link rubs on bottom and jams?
Re: wiper motor [Re: 300_dup5] #1157208
01/14/12 05:40 PM
01/14/12 05:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Can the drive link be installed differently then you have it now.
Re: wiper motor [Re: stumpy] #1157209
01/14/12 06:21 PM
01/14/12 06:21 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
My '80 Aspen two speed motor has big rubber spacers attached to the oem motor.
Facts are stubborn things.
Re: wiper motor [Re: larrymopar360] #1157210
01/14/12 06:55 PM
01/14/12 06:55 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Ya changed link around 4 yes. You forget even with a manual
