Is 431 ci enough? #1157185
01/14/12 03:33 PM
01/14/12 03:33 PM
USA
hudsonhornet7x Offline OP
USA
I am new to moparts, and I have a question:
I currently have a stroked 383(431) short block in my garage.
Car is a 2nd gen charger with a 4 speed.
Car will see lots of street use with drag days thrown in.
Is the 431 enough motor for a 69 charger? Or will I be wishing I built a 470- 500 " motor.
Indy has a 470" kit with a machined 400 block for $ 2500. Would that be a better choice, or will I be better off buying a killer set of heads for the 431?
Remember, I am looking for a hot street car with occasional drag use.
Thanks, as I do not know what to do!!
Re: Is 431 ci enough? [Re: hudsonhornet7x] #1157186
01/14/12 04:21 PM
01/14/12 04:21 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Outlining your performance expectations and requirements / limitations would help a lot in providing an answer.
Re: Is 431 ci enough? [Re: BradH] #1157187
01/14/12 04:52 PM
01/14/12 04:52 PM
USA
USA
I need a reliable motor for use in the summer, and wild enough to pull high 10's-low 11's in the 1320.
Re: Is 431 ci enough? [Re: hudsonhornet7x] #1157188
01/14/12 05:27 PM
01/14/12 05:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
At the weight of the Charger B-body I would take the more cubes if I could afford it. It can always use the extra torque to reach your goal. Ron
Re: Is 431 ci enough? [Re: hudsonhornet7x] #1157189
01/14/12 06:06 PM
01/14/12 06:06 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You need more cubes or nitrous ...
Re: Is 431 ci enough? [Re: JohnRR] #1157190
01/14/12 06:25 PM
01/14/12 06:25 PM
USA
USA
Okay, would the 470" do the job from Indy? Seems like a good deal at $ 2500 for the block and rotating assembly.
If not, what short block/ head combo would do what I require?
Re: Is 431 ci enough? [Re: hudsonhornet7x] #1157191
01/14/12 06:42 PM
01/14/12 06:42 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Dont buy a shortblock from Indy.
Re: Is 431 ci enough? [Re: hudsonhornet7x] #1157192
01/14/12 07:04 PM
01/14/12 07:04 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Heavy car, you need a 500 incher if you want to run 10's without spending a ton of $$$$. Indy does not have a good rep for machining or customer service.
Sheldon
Re: Is 431 ci enough? [Re: RUNCHARGER] #1157193
01/14/12 07:40 PM
01/14/12 07:40 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
You will probably want to go right to 500ci's. Give muscle motors or Best machine a call. Today stroker kits are priced very well for most racers.
P.S. welcome to moparts!
Re: Is 431 ci enough? [Re: Diablo] #1157194
01/14/12 08:40 PM
01/14/12 08:40 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
A short block is just the begining of your list of needs. Hard to combine your comment that car will see lots of street use, dependable, and cut a 10 second ET. Besides keeping it running cool water temps, everything behind that engine has to be able to hold up, then you have to hook it to the street.
Many here with track cars try to do this. Be prepared to spend 10-12k on your set up, not even considering the SFI stuff your going to run. then it has to tech to run those times.
Re: Is 431 ci enough? [Re: hudsonhornet7x] #1157195
01/14/12 10:02 PM
01/14/12 10:02 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Get a 440 block and build a motor like 383man has.
Re: Is 431 ci enough? [Re: Mopar-Al] #1157196
01/14/12 11:18 PM
01/14/12 11:18 PM
ill
dennismopar73 Offline
ill
I have a 437 build, but not as a street motor, but I firmly believe that high 10s could be achieved, without a whole lot of issues.
But rest assured the weight will work against it , lose weight where you can!
Putting the right cam,heads intake package,will be key as well as the converter you choose.
I could see that 430-maybe 410 gears could do it?
Re: Is 431 ci enough? [Re: dennismopar73] #1157197
01/15/12 12:25 AM
01/15/12 12:25 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
"THERE IS NO SUBSTITUTE FOR CUBIC INCHES"
home of the
Sox and Martin Hemi Duster
Re: Is 431 ci enough? [Re: hudsonhornet7x] #1157198
01/15/12 12:37 AM
01/15/12 12:37 AM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
I built a 431 about 15 years ago, and it's plenty of engine, runs great to this day, but high-10s/low 11s and street use in summer is a little hard to get out of a 431 in a B Body. Reliable and street, absolutely! A hot cam and exhaust will help speed but hurt street and reliability.
I'd seriously consider going one way or the other, i.e. all out strip and shoot for 10s, or build up a killer street machine with good sound, reliability and ease of maintainance, while still being faster than 98% of all cars on the street, but no where near 10 second 1/4 mile times. Either way, good luck!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: Is 431 ci enough? [Re: AdventurerSport] #1157199
01/15/12 12:49 AM
01/15/12 12:49 AM
USA
USA
Guys I do appreciate the answers. The 431 I have is almost ready to be broken in, so you see my dilema!
I have been thinking about a set of standard port Victors that are hogged out. Between thse heads and a good cam setup I wonder how it would run...... I am stubborn enough to try!
By the way, the car is a 4 speed and I plan to purchase a Dana so I can pick any gear I need. Not stuck with what I have.
Fire away with any head/cam/gear suggestions.
Re: Is 431 ci enough? [Re: hudsonhornet7x] #1157200
01/15/12 01:14 AM
01/15/12 01:14 AM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Going 10s is doable with 431" and streetable. The winners of drag week in the small block, normal aspiration class run in the mid 10s with, by rule having less than 431"!
This post is available in double vision where drunk.
Re: Is 431 ci enough? [Re: bwdst6] #1157201
01/15/12 02:45 AM
01/15/12 02:45 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
If I were you I would get some nice std. port aluminum heads/ported and a mild solid roller and see where you end up. Std. Victors would be nice too. May not be 10s but you would be close.
If you already have the shortblock ready, it wouldn't be money well spent to get a different one. For the street id go with 4.1 gear and 3500-4000 stall.
Re: Is 431 ci enough? [Re: viperblue72] #1157202
01/16/12 07:39 AM
01/16/12 07:39 AM
gregsdart Offline
gregsdart  Offline
Head flow and RPM will be your friend hear to make the 431 work. A good set of aftermarket standard size port heads, single plane intake, 1 7/8 headers and a matched solid cam to run 6500 to 6700 rpm will help you build power needed to make your goal. If it is not too late, relieve the cylinders at the top of the bore next to the intake valves like the 426 SS motors did to help intake flow. Be carefull not to go to far down the bore.
On the size of the cam, it will take duration in the 255 + range at .050 cam lift with total lift of .550 or more to make use of good heads and reach your goal. The highest gear ratio you can tolerate out back will help as well. A 4.10 gear or more will help a lot but if you can tolerate a 4.56 I would go with it. Combined with a 27 inch drag radial for the track and the tallest tire you can stuff under it for the street, it should work pretty good.
Re: Is 431 ci enough? [Re: bwdst6] #1157203
01/16/12 11:07 AM
01/16/12 11:07 AM
JohnRR Offline
JohnRR  Offline
Was it in an almost 4000lb car ?
Re: Is 431 ci enough? [Re: JohnRR] #1157204
01/16/12 11:19 AM
01/16/12 11:19 AM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
A few questions:
1. Are the pistons forged? How about the crank? As someone has already mentioned, nitrous would go a long ways to help you get into the 10s/11s.
2. What type of cam set up are you looking for? Solid or hydraulic? Flat tappet or roller? Rollers are nice.
3. What type of rear end gears are you looking at? To get into the 10s/11s, you're probably going to need at least 4.10s, which won't be friendly on your gas mileage when the car is street-driven. DAMHIK.
That said - I would recommend the Indy SRs. If you stick with the 431 block and go with SRs, you won't have to buy the high-dollar TTI headers that you have to use with the SRs if you're running an RB. The EZs are something else to consider, but IMHO they don't have as much potential as the SRs. The Victors could be overkill for 431.
Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
