Re: Is 431 ci enough?
[Re: hudsonhornet7x]
#1157189
01/14/12 06:06 PM
01/14/12 06:06 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
I need a reliable motor for use in the summer, and wild enough to pull high 10's-low 11's in the 1320.
You need more cubes or nitrous ...
#1157191
01/14/12 06:42 PM
01/14/12 06:42 PM
Posts: 3,395 Pa
Hot 340
Pa
Okay, would the 470" do the job from Indy? Seems like a good deal at $ 2500 for the block and rotating assembly.
If not, what short block/ head combo would do what I require?
Dont buy a shortblock from Indy.
[Re: RUNCHARGER]
#1157193
01/14/12 07:40 PM
01/14/12 07:40 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
You will probably want to go right to 500ci's. Give muscle motors or Best machine a call. Today stroker kits are priced very well for most racers.
P.S. welcome to moparts!
[Re: Mopar-Al]
#1157196
01/14/12 11:18 PM
01/14/12 11:18 PM
Posts: 2,177 ill
dennismopar73
ill
I have a 437 build, but not as a street motor, but I firmly believe that high 10s could be achieved, without a whole lot of issues. But rest assured the weight will work against it , lose weight where you can! Putting the right cam,heads intake package,will be key as well as the converter you choose. I could see that 430-maybe 410 gears could do it?
#1157198
01/15/12 12:37 AM
01/15/12 12:37 AM
Posts: 6,018 Morningside
AdventurerSport
waaaay out there in left field
Morningside
I built a 431 about 15 years ago, and it's plenty of engine, runs great to this day, but high-10s/low 11s and street use in summer is a little hard to get out of a 431 in a B Body. Reliable and street, absolutely! A hot cam and exhaust will help speed but hurt street and reliability.
I'd seriously consider going one way or the other, i.e. all out strip and shoot for 10s, or build up a killer street machine with good sound, reliability and ease of maintainance, while still being faster than 98% of all cars on the street, but no where near 10 second 1/4 mile times. Either way, good luck!
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: AdventurerSport]
#1157199
01/15/12 12:49 AM
01/15/12 12:49 AM
Posts: 1,541 USA
hudsonhornet7x
USA
Guys I do appreciate the answers. The 431 I have is almost ready to be broken in, so you see my dilema! I have been thinking about a set of standard port Victors that are hogged out. Between thse heads and a good cam setup I wonder how it would run...... I am stubborn enough to try! By the way, the car is a 4 speed and I plan to purchase a Dana so I can pick any gear I need. Not stuck with what I have. Fire away with any head/cam/gear suggestions.
#1157200
01/15/12 01:14 AM
01/15/12 01:14 AM
Posts: 970 Backwater, PA
bwdst6
Bob George Racing #1 Fan
Backwater, PA
Going 10s is doable with 431" and streetable. The winners of drag week in the small block, normal aspiration class run in the mid 10s with, by rule having less than 431"!
This post is available in double vision where drunk.
[Re: bwdst6]
#1157201
01/15/12 02:45 AM
01/15/12 02:45 AM
Posts: 2,141 junction city oregon
viperblue72
If I were you I would get some nice std. port aluminum heads/ported and a mild solid roller and see where you end up. Std. Victors would be nice too. May not be 10s but you would be close. If you already have the shortblock ready, it wouldn't be money well spent to get a different one. For the street id go with 4.1 gear and 3500-4000 stall.
[Re: viperblue72]
#1157202
01/16/12 07:39 AM
01/16/12 07:39 AM
Posts: 9,999 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Head flow and RPM will be your friend hear to make the 431 work. A good set of aftermarket standard size port heads, single plane intake, 1 7/8 headers and a matched solid cam to run 6500 to 6700 rpm will help you build power needed to make your goal. If it is not too late, relieve the cylinders at the top of the bore next to the intake valves like the 426 SS motors did to help intake flow. Be carefull not to go to far down the bore. On the size of the cam, it will take duration in the 255 + range at .050 cam lift with total lift of .550 or more to make use of good heads and reach your goal. The highest gear ratio you can tolerate out back will help as well. A 4.10 gear or more will help a lot but if you can tolerate a 4.56 I would go with it. Combined with a 27 inch drag radial for the track and the tallest tire you can stuff under it for the street, it should work pretty good.
[Re: bwdst6]
#1157203
01/16/12 11:07 AM
01/16/12 11:07 AM
JohnRR
U.S.S.A.
Was it in an almost 4000lb car ?
[Re: JohnRR]
#1157204
01/16/12 11:19 AM
01/16/12 11:19 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
A few questions: 1. Are the pistons forged? How about the crank? As someone has already mentioned, nitrous would go a long ways to help you get into the 10s/11s. 2. What type of cam set up are you looking for? Solid or hydraulic? Flat tappet or roller? Rollers are nice. 3. What type of rear end gears are you looking at? To get into the 10s/11s, you're probably going to need at least 4.10s, which won't be friendly on your gas mileage when the car is street-driven. DAMHIK. That said - I would recommend the Indy SRs. If you stick with the 431 block and go with SRs, you won't have to buy the high-dollar TTI headers that you have to use with the SRs if you're running an RB. The EZs are something else to consider, but IMHO they don't have as much potential as the SRs. The Victors could be overkill for 431. Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
