What's the best way to pull..... #1156787
01/14/12 07:26 AM
01/14/12 07:26 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
....the manual brake rod out of the master? Thanks in advance.
Moparlee
Re: What's the best way to pull..... [Re: Robbins] #1156788
01/14/12 10:00 AM
01/14/12 10:00 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Is it still in the car? If so, remove the brake switch bracket and grab hold of the pedal and give a good yank.
Re: What's the best way to pull..... [Re: Todd] #1156789
01/14/12 10:16 AM
01/14/12 10:16 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
No, but I guess I could put it back in and try that.
Moparlee
Re: What's the best way to pull..... [Re: Robbins] #1156790
01/14/12 10:22 AM
01/14/12 10:22 AM
if your hyd floor jack has a center hole in the round plate that contacts the work, set the MC/pushrod vertical down into it then slip a rod horizontle under the jack thru the eyelet then pump it up & put a rag around the flange to keep from marring/nicking it but that shouldn't be a prob or clamp the flange in a vise & a rod thru the eyelet and a good yank or 2 to seperate em
Re: What's the best way to pull..... [Re: RapidRobert] #1156791
01/14/12 10:26 AM
01/14/12 10:26 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
dont forget to GRUNT, i mean REALLY GRUNT.
Re: What's the best way to pull..... [Re: RapidRobert] #1156792
01/15/12 04:26 AM
01/15/12 04:26 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
That done it for me. Bent one thing(a home made t-handle allen that I had made a long time ago) and then tried one of my old punches...bent it and snapped the point off with my floor jack. I would of never got that out by hand. Thanks again for the idea.
Moparlee
