Rear axle disc brake master cylinder/booster which one? #1156763
01/14/12 06:18 AM
01/14/12 06:18 AM
across the river from Portland...
472 R/T SE Offline OP
I'm gonna update the wheels/tires on my Charger this spring. It was that or a 671 or 871. Maybe the next upgrade?
They'll be 17's on the rear & 16's up front
-17's all the way around
-18's on the rear & 17's up front.
No bigger than that.
I haven't decided yet. It will have plenty of rubber though. Just say no to rubber band tires is my motto.
I'm sure there's several folks who question me ruining this car. I do have the #'s drivetrain. But all my mods will be easy to change over. With this latest endeavor I might try & find a Ford truck Dana to mod or another 8 3/4. Since I'm running Cal Tracs I don't need to worry about the truck Dana not having a pinion snubber.
So my questions:
-Which rear would be easier on the wallet to add disc brakes to?
-My booster & master cylinder. Do I have to go with hydroboost?
-Is there a factory appearing master cylinder that has 2 big reservoirs' that would mount to the Bendix booster?
I'm not concerned about vacuum as I already am running a pump.
I've seen a few rides using the factory disc/drum master cylinder with the two different size reservoir's. Just because they're doing it doesn't make it right.
TIA
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
Re: Rear axle disc brake questions. [Re: 472 R/T SE] #1156764
01/14/12 06:28 AM
01/14/12 06:28 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
If you run a mopar axle, you can use the jeep grande Cheorkee rear discs. If you run a dana, get the ford ends and use the Ford explorer discs. They are both the same brake calipers and rotors, the only difference is in the parking brake hardware but the pad and shoes also interchange. If you want killer fronts, use the explorer front calipers and crown vic rotors. This is all stock parts and can be found in most parts stores. Tim
Re: Rear axle disc brake questions. [Re: 472 R/T SE] #1156765
01/14/12 11:39 AM
01/14/12 11:39 AM
Detroit boy in Saugerties, NY
BrianShaughnessy Offline
If I had to do things over again...
I'd still go Dana 60. But I'd just call up DoctorDiff and tell him to build it with torino ends and his rear disk kit with a truetrac diff.
No green bearings, no tracloc. No local friend that doesn't work on mopars cutting up a junkyard ford truck dana, and no aerospace rear disks with $200 warped wilwood rotors.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana.
Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart.
El Grande: '98 Grand Cherokee 5.9 Limited.
Re: Rear axle disc brake questions. [Re: 472 R/T SE] #1156766
01/14/12 01:41 PM
01/14/12 01:41 PM
AndyF Offline
AndyF  Offline
Just talk to Cass at DoctorDiff. He can set you up with a good rear disc kit at a reasonable price.
Re: Rear axle disc brake questions. [Re: AndyF] #1156767
01/14/12 01:50 PM
01/14/12 01:50 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
Andy, whose rear sway bar set up is on the car in the picture? Looks like a fair amount of choice for setting it up.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Rear axle disc brake questions. [Re: AndyF] #1156768
01/14/12 01:52 PM
01/14/12 01:52 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
You could also try Kore3, they a rear kit for a 8 & 3/4 a guy local to me has them on his 42 Plymouth.
www.kore3.com
A new iron curtain drawn across the 49th parallel
Re: Rear axle disc brake questions. [Re: racealittle] #1156769
01/14/12 03:15 PM
01/14/12 03:15 PM
AndyF Offline
AndyF  Offline
The rear bar was custom built by Tim who owns the Valiant. Firm Feel can build you a similiar bar if you want one.
Re: Rear axle disc brake questions. [Re: AndyF] #1156770
01/14/12 03:20 PM
01/14/12 03:20 PM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
On our Lemons car we run the Dr. Diff rear disc brakes and they work fantastic. We use our car harder than anybody (4000 pound C-Body) and they never fade. The brakes are Mustang Cobra sourced.
On wheel size you pretty much have to run at least 17's to get a decent tire choice. We run the Dunlop Direzza Star Specs, best track day tire for the money out there. They are a summer/performance tire only however. The other tire guys are really liking right now is the Falken Azezzi's (sp?) but have heard they tend to work better on lighter cars. Hoping to experiment with both tires this summer.
Rocket Restorations
Re: Rear axle disc brake questions. [Re: tallzag] #1156771
01/14/12 04:14 PM
01/14/12 04:14 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So that Dunlop is the current HOT street tire everyone is going to right now??
Duly noted. Thank you. Going to get some 275/40/17's soon.
Re: Rear axle disc brake questions. [Re: autoxcuda] #1156772
01/14/12 05:11 PM
01/14/12 05:11 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Just as a note on the green bearings; I asked about the Hotchkiss RR rear discs at MATS last year.
It uses discs with green bearings. He said that they have to replace them every 6 months!
You probably won't be running the laps they do, but I would not be happy with that kind of lifespan!
Re: Rear axle disc brake questions. [Re: RodStRace] #1156773
01/14/12 05:17 PM
01/14/12 05:17 PM
AndyF Offline
AndyF  Offline
That is a good point. Many of the rear disc kits require a switch to the green bearings. That is one of the reasons why I always recommend the DoctorDiff kit. He is one of the few guys who actually bothered to design his kit to work with the stock tapered bearings. Many mfgs just rebox a Chevy kit for the Mopar application.
With the DoctorDiff kit the bracket replaces the backing plate and the thrust clearance is set just like a drum brake.
Re: Rear axle disc brake questions. [Re: AndyF] #1156774
01/14/12 05:26 PM
01/14/12 05:26 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That's a transport tie down eye on the u bolt plate?
Re: Rear axle disc brake questions. [Re: jcc] #1156775
01/14/12 09:33 PM
01/14/12 09:33 PM
Thanks for the responses, really appreciated it.
What about booster & master cylinder?
Re: Rear axle disc brake questions. [Re: jcc] #1156776
01/14/12 10:25 PM
01/14/12 10:25 PM
AndyF Offline
AndyF  Offline
Chassis dyno tie down, but it also can be used for trailering.
Re: Rear axle disc brake questions. [Re: AndyF] #1156777
01/14/12 11:07 PM
01/14/12 11:07 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What thrust clearance did you shoot for on Tim's Valiant?
Dan W. with the Hotchkis RR complains about pad knockback with tapered and green bearing. I think he's going to a floater rear end. Wonder what Tim W. opinions and experiances on this issue.
Re: Rear axle disc brake questions. [Re: tallzag] #1156778
01/15/12 10:34 AM
01/15/12 10:34 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
some of the guys here have been running the star specs - until we discovered the hankook ventus RS - unbelieveable tire and the price is just as unbelieveable - will be running them this summer again...only downside to them is not a huge range of sizes...
Re: Rear axle disc brake questions. [Re: autoxcuda] #1156779
01/15/12 08:04 PM
01/15/12 08:04 PM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
That is the size tire we currently run in the Dunlop's (although we just picked up a set of 18's ). The problem with tires like the Hankook is we run the 24 Hours of Lemons and they require a 190 tire treadwear or higher, the Hankook's are 140.
Rocket Restorations
Re: Rear axle disc brake master cylinder/booster which one? [Re: 472 R/T SE] #1156780
01/17/12 01:37 AM
01/17/12 01:37 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My combo defies logic, but it works.
1970 Charger with 12" Cordoba front discs, 11.7 rear discs with a power booster and Master cylinder spec'd for a 75 Dart with disc brakes. In reality, I expected it to be overly biased to the front brakes, but it really works well.
Re: Rear axle disc brake master cylinder/booster which one? [Re: Kern Dog] #1156781
01/21/12 07:04 PM
01/21/12 07:04 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
What are piston sizes? I'll bet that's what you did right, without realizing it!
Re: Rear axle disc brake master cylinder/booster which one? [Re: Rick_Ehrenberg] #1156782
01/21/12 07:13 PM
01/21/12 07:13 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Thats high praise, Rick. You are well respected.
I used front calipers spec'd for the master cylinder/power booster 75 Dart. I think that I read in Mopar Action that they changed the A body caliper in 1976? When I ordered the rear kit from Dr Diff, I told him of my existing combo which had 10" drums in the rear. He thought that it would work with the 75 A master cylinder and it certainly has.
I love the bias, but I am tempted to eliminate the booster. While the combo works great from 20 mph and up, the minimal vacuum from the '509 cam makes slow speed braking a bit nerve wracking.
I just had the car out for about 45-50 minutes, taking corners and doing a little flexing of the muscles. I really enjoy this car!
