Show off your pics of Shift Light / Tach mounting. #1156465
01/13/12 04:06 PM
01/13/12 04:06 PM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
Getting a new shift light and I'm pretty sure where I'll mount it, but want to see where you guys have yours set up.
Re: Show off your pics of Shift Light / Tach mounting. [Re: LAR_414] #1156466
01/13/12 04:14 PM
01/13/12 04:14 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
my big tach is getting fixed. the light mounts to it in place of the little one
I am truckless..
Re: Show off your pics of Shift Light / Tach mounting. [Re: LAR_414] #1156467
01/13/12 04:42 PM
01/13/12 04:42 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
when I had the Duster
how its mounted in the Camaro
Re: Show off your pics of Shift Light / Tach mounting. [Re: smokinwoody] #1156468
01/13/12 06:16 PM
01/13/12 06:16 PM
South Lyon, Michigan
6bblRoadrunner Offline
Nothin fancy...just mounted to the column.
Re: Show off your pics of Shift Light / Tach mounting. [Re: LAR_414] #1156469
01/13/12 06:48 PM
01/13/12 06:48 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
In the mock up stage, but I'm not putting a tach in the RoadRunner just a shift light. Painted it and the aluminum steering column the factoy blue suede.
69 GTX 68 Road Runner
Re: Show off your pics of Shift Light / Tach mounting. [Re: JERICOGTX] #1156470
01/13/12 08:55 PM
01/13/12 08:55 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
here is mine
Re: Show off your pics of Shift Light / Tach mounting. [Re: JERICOGTX] #1156471
01/13/12 09:07 PM
01/13/12 09:07 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
That is slick! Nice
Re: Show off your pics of Shift Light / Tach mounting. [Re: 69B3GT] #1156472
01/13/12 09:18 PM
01/13/12 09:18 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
We've done a few like this. it bolts into the dash vent spot sits flush and doesnt touch the dash pad.
Re: Show off your pics of Shift Light / Tach mounting. [Re: ChrisJohnston669] #1156473
01/13/12 10:53 PM
01/13/12 10:53 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Here's mine
And hee's what we have in my wifes car....
Re: Show off your pics of Shift Light / Tach mounting. [Re: WILD BILL] #1156474
01/13/12 11:44 PM
01/13/12 11:44 PM
LAR_414 Offline OP
LAR_414  Offline OP
That's exactly what I'm doing. Getting rid of my tach and just running a Shift light. Actually a shift light with a digital rpm in it as well, but no more big circle tach.
Looks good guys...thanks
Re: Show off your pics of Shift Light / Tach mounting. [Re: LAR_414] #1156475
01/13/12 11:53 PM
01/13/12 11:53 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
I feel you have more flexibility using a big tach with a shift light. I frequently try different shift points so monitoring rpm once I pull 2nd gear is a big plus for me. I tried the digital tube tach and it was too hard to keep my eyes focused while driving
Re: Show off your pics of Shift Light / Tach mounting. [Re: LAR_414] #1156476
01/14/12 12:04 AM
01/14/12 12:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have a small tach on the steering column and the shift light is under the cowl
Re: Show off your pics of Shift Light / Tach mounting. [Re: Mr.Yuck] #1156477
01/14/12 12:51 PM
01/14/12 12:51 PM
metro detroit
turner Offline
turner  Offline
metro detroit
I didnt want mine to be seen from outside the car(still pulls double duty on the street), so I mounted it on a piece of stainless from the two sheeet metal screws above my ashtray, car has made 350+ passes and hasnt fell off yet!
Re: Show off your pics of Shift Light / Tach mounting. [Re: turner] #1156478
01/14/12 03:18 PM
01/14/12 03:18 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
Here is the one in my 74 Duster, just like another I saw on here. Uses the vent mouting holes, Just a different angle. see ya, Ken
Re: Show off your pics of Shift Light / Tach mounting. [Re: 1974 474 Duster] #1156479
01/14/12 03:20 PM
01/14/12 03:20 PM
71 Duster put into the Ralley dash where the speedo used to be on it. Thanks, Ken
Re: Show off your pics of Shift Light / Tach mounting. [Re: LAR_414] #1156480
01/14/12 04:01 PM
01/14/12 04:01 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Here's mine...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Show off your pics of Shift Light / Tach mounting. [Re: DemonDust] #1156481
01/14/12 04:12 PM
01/14/12 04:12 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
do not mind the ugly wheel. i got a nother one last month
Re: Show off your pics of Shift Light / Tach mounting. [Re: dmking] #1156482
01/14/12 04:29 PM
01/14/12 04:29 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
As usual I've got to be different...
Re: Show off your pics of Shift Light / Tach mounting. [Re: LAR_414] #1156483
01/14/12 06:59 PM
01/14/12 06:59 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My shift light was mounted to a rod that came off the pillar bar.
Re: Show off your pics of Shift Light / Tach mounting. [Re: ProSport] #1156484
01/14/12 08:21 PM
01/14/12 08:21 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
Mine is a street car so I wanted it slightly out of view. Mounted it to the column.
