Re: chassis rigidity??
[Re: A57_RT ]
#1156046
01/13/12 01:57 PM
01/13/12 01:57 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Depends what the car will be used for. All out racing, street/road course/autocross, or street only with some spirited driving? Too stiff and the car will 'hop' and 'chatter' across the road or track.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: autoxcuda]
#1156049
01/13/12 03:46 PM
01/13/12 03:46 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Taking chassis flex out of the picture will rear the ugly head of inadequate suspension components.
Mopar to the bone!!!
[Re: autoxcuda]
#1156051
01/13/12 11:50 PM
01/13/12 11:50 PM
Posts: 6,015 Salem
Grizzly
Moparts Proctologist
Salem
Autoxcuda: That photo that you attached is stinkin' awesome.
Mo' Farts
Moderated by "tbagger".
[Re: A57_RT ]
#1156052
01/14/12 12:31 AM
01/14/12 12:31 AM
72Swinger
Nebraska
My point was that a stiff chassis will need absorbtion from its suspension. I stiffened my front unibody up a bunch and it is now glaring that I seriously need bigger tbars and better shocks bigtime.
[Re: 72Swinger]
#1156053
01/14/12 12:56 AM
01/14/12 12:56 AM
Posts: 22,697 Bitopia
jcc
Bitopia
Are you sure about that, because as I understand it, if we are talking the about driving the same circuit, and the only change was to stiffen the chassis, it would seem some of the compliance was taken out of the suspension equation, meaning a softer set-up would be needed to have exact same performance, am I missing something?
Do you mean stiffen to maintain correct geometry?
Suspension tuning is based on compliance and resonance of all springy parts, tires, tire pressure, TB, shocks, bushing compliance, control arm compliance, chassis compliance, etc. If you make one stiffer, some other combination needs to be softer to maintain same ride quality.
[Re: Grizzly]
#1156054
01/14/12 01:46 AM
01/14/12 01:46 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Autoxcuda:
That is Tim Werner's Valiant.
And that car has the motor AndyF built in Mopar Muscle magazine. I believe AndyF took the picture too.
[Re: AndyF]
#1156058
01/14/12 02:38 AM
01/14/12 02:38 AM
Posts: 31,061 Oregon
AndyF
Here is a shot of the front down tube. I think that the down tube needs to be tied into the shock mount so that might be one of the mods that we add this winter. Just a couple of pieces of steel tying the shock mount to the sheet metal and the roll bar tube should do the job.
[Re: jcc]
#1156061
01/14/12 04:34 AM
01/14/12 04:34 AM
72Swinger
Nebraska
Yeah im positive about that. Think about that flex as an extra shock that gets taken away from the equation. Now your existing shocks and tbars are doing more of the absorbing and the same bump you hit 100 times before now makes you bottom out. Makes perfect sense to me....
[Re: AndyF]
#1156062
01/14/12 04:43 AM
01/14/12 04:43 AM
72Swinger
Nebraska
I have lots of pictures of Tim's car since the last couple of builds were done in my shop. Here is a shot of the XV brace up front. You can also see the down bars in the engine compartment.
Absolutely love the Valiant Andy! web page mine is round tube but seems to work nicely.
[Re: A57_RT ]
#1156063
01/14/12 02:17 PM
01/14/12 02:17 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
How important and what is too much?
How important is a good foundation when building a house? Same concept. If your chassis is not adequatly braced to support the suspension, you allow the uni-body to become an active, yet inconsistent participant in the suspension system. The key is how much bracing and support is adequate without tremendous increases in sprung weight. Combine that with the need to mount the engine, trans, other components and the possibility of any rules restrctions, and that is the challenge facing ultimate rigidity.
In a street car, simply mods like torque boxes or subframe connectors are adequate. The more spirited you use the vehicle, the greater the benefit of additional bracing, up to competition levels where cage structure then has to be taken in to consideration.
[Re: 72Swinger]
#1156064
01/14/12 04:28 PM
01/14/12 04:28 PM
jcc
Bitopia
Then consider this, say we have a car that you are going to stiffen up the chassis by any means you desire. Say you want/expect the car to have the relative same handling characteristics after mods are completed ( and as mentioned a post or two before chassis stiffening will make car more consistent/predictable).
So if for simplicity we imagine the car has say 4? "springs" of different rates/resonances IE tires at a certain pressure, the TB's, the chassis flex (which really is a spring as long as it returns to original shape after removal of road loads) and the drivers seat suspension. To keep matters very simple. If all these "springs" say add up to some magical value "X", removing or reducing any of them will reduce the "springiness" of the system, and in order to keep the same ride stated above, something or combination needs to be soften to maintain same ride quality. However without any readjustment, the suspension being more rigid may exhibit less shake feel more predictable, and allow an increase in other "spring" rates until chassis flex(spring) reappears due to greater loads or another spring becomes too soft for the new application.
Bottom line, increasing Chassis stiffness does not automatically require increase spring rates for same ride, and that makes sense to me, and I guess we still disagree
