Re: XX29; '69 Charger 500 project. update 03/13/12
[Re: hemi68charger]
#1156002
06/27/12 08:10 PM
06/27/12 08:10 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Center grille and passenger side in and even got the lights to work...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1156003
06/27/12 08:11 PM
06/27/12 08:11 PM
hemi68charger
Houston, Tx
Time to work on the driver's side headlamp bucket. Now I'm working on a "clone" mirror image of the NOS headlamp bucket for the passenger side. I was able to acquire a '68 Coronet headlamp bucket cut out of a fender. It is exactly what I was looking for. I have cut away most of the unusable metal from the '68 Coronet bucket using the original piece as a template. Today also duplicated the inner attach bracket by placing tape over the original and outlining it. I place the tape on a piece of spare sheetmetal and cut away... Came out pretty good if I say so.. I wish I had a pinch welder for I would have done that. But, I just went ahead and fastened it with sheetmetal screws for now.. It'll work and is hidden...
1. right is original C500 headlamp bucket
[Re: hemi68charger]
#1156004
06/27/12 08:12 PM
06/27/12 08:12 PM
hemi68charger
Houston, Tx
2. you can see the bracket I'm duplicating
[Re: hemi68charger]
#1156006
06/27/12 08:13 PM
06/27/12 08:13 PM
hemi68charger
Houston, Tx
4. bracket fastened.
I'll eventually paint the complete unit gray like the original
Re: XX29; '69 Charger 500 project - 06/28/2012
[Re: hemi68charger]
#1156010
06/28/12 10:08 PM
06/28/12 10:08 PM
hemi68charger
Houston, Tx
Got an early present today; new fuel lines for the 500...
Re: XX29; '69 Charger 500 project - 01/16/2012
[Re: hemi68charger]
#1156011
06/30/12 12:38 PM
06/30/12 12:38 PM
hemi68charger
Houston, Tx
Old and new... Looking forward in getting these in.. One step closer to road-worthy independence...
XX29; '69 Charger 500 project - 03 Jul, brakes
[Re: hemi68charger]
#1156012
07/03/12 08:24 PM
07/03/12 08:24 PM
hemi68charger
Houston, Tx
Well, I think I have the brakes straightened out..
Things I've done: All new brake lines (OEM from Finelines) disassembled safety and proporationing valve and cleaned. rebuilt both rear wheel cylinders, new drum hardware rebuilt both front 4-pistion calipers with new pads (thanks Doug) new master cylinder - booster seems to be fine.
-I had my son help me bleed the brakes.. Nice that he's tall enough now to reach the pedals..
-Everything seemed fine. Car is on jacks. Put rear wheels/tires back on and tested it.. Didn't have the booster connected (something I quickly learned needed to be done for power brakes)
-after connecting booster to intake vacuum source, rear wheels stop very nice while in drive spinning... Good news..
- now I'll reconnect the driver's tie-rod to the pitman arm and reinstall front wheels/tires.. Lower her and try backing her out into the driveway and try multiple back and forth stopping...
XX29; '69 Charger 500 project - 04 Aug, floor pan here
[Re: MuuMuu101]
#1156016
08/04/12 01:23 PM
08/04/12 01:23 PM
hemi68charger
Houston, Tx
Hey gang.... Got my new floor pan from AMD.. 1st purchase with the money I earned putting together the '71 six pack Challenger R/T I have at the house... Now, I have another friend who's going to put it in for me for free.... Looking forward to that.......
Cheers,, Troy
XX29; '69 Charger 500 project - 30 Sept
[Re: hemi68charger]
#1156017
09/30/12 11:15 PM
09/30/12 11:15 PM
hemi68charger
Houston, Tx
Update today.. A very good day out in the garage.. As been updated, been working on the grille and naturally the headlamps are part of it. Then, I went to the parking lights and while I was on a roll, I tackled the hood indicators.. yesnod Came out pretty good... So, electrically, it's getting better... 2thumbs http://youtu.be/XzNQ7tdk738
