off set mounts?? #1155732
01/13/12 01:27 AM
01/13/12 01:27 AM
moscow mills mo
smracing Offline OP
smracing  Offline OP
moscow mills mo
does any one offer engine and trany mounts
to move a rb back further for a better cg?
or a tubular frame that will do this? for an E body
not worried about the fire wall will modify as needed
thanks
new forum is great to see up and running or should I turning a new corner
Re: off set mounts?? [Re: smracing] #1155733
01/13/12 02:16 AM
01/13/12 02:16 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
thanks
If you can do you own firewall mods, you should be able to do the engine and trans mounts. Oil pan to center link and headers are the big "issue things" that pop into my mind first.
IMHO that a project that needs to be fitted to the car. Not something for a "kit".
Longer quick ratio idler and pitman arms move the center link back about an inch, IIRC. That could help with rearward pan clearance.
