Here is the setup 440 30 over stock stroke 9-1 comp out of the box eddy 88cc. Small hyd roller. F.A.S.T efi with a eddy pro-flo xt manifold with 90 m throttle body.
Borgwarner s400 80 mil turbo with a 1.32 ar .I want to run 91 pump gas I saw a guy at Columbus with 451 B motor who had pro charger running 15 Lbs of boost on the street with 100 lbs injectors. This is a street strip car I'm building with a stock block with aluminum caps and girdle.
Anyone have any advice I'm looking at 85-95 lbs inj some real world experience
Would be great.
