'70 e-body spindle strong enough to run 12" rotor? #1155541
01/12/12 09:51 PM
01/12/12 09:51 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Hi guys, want to run 12" rotors on my AAR (came with discs)...I know bearing adapters exist to run the larger wheel bearings on the 70~72 spindles.
Is there anything to worry about with the smaller spindle diameter, or am I worrying about nothing?
p.s. will be used for street driving, no autocrossing.
Thanks!
Re: '70 e-body spindle strong enough to run 12" rotor? [Re: kielbasa] #1155542
01/12/12 10:42 PM
01/12/12 10:42 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I doubt you will have a problem. Ford and GM used the same "small" spindle diameter for years regardless of engine size/vehicle weight.
Re: '70 e-body spindle strong enough to run 12" rotor? [Re: DoctorDiff] #1155543
01/12/12 11:33 PM
01/12/12 11:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Chrysler went to the larger spindle not for strength but to fit the larger bearing... The smaller bearings were prone to failure... Cass's bearing spacer allows the big bearing to be used with the small spindle, similar spacers are used in industrial applications without issues every day...
Re: '70 e-body spindle strong enough to run 12" rotor? [Re: 1_WILD_RT] #1155544
01/13/12 12:09 AM
01/13/12 12:09 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Some of AndyF Brembo caliper and big disk conversions use an even lighter 73-76 A-body drum spindle. Tim Werners 68 Valiant has run that setup on the track up to 140+ mph cutting some very impressive lap times!
