Re: School me on control arm bushings
[Re: DaytonaTurbo]
#1155386
01/12/12 06:01 PM
01/12/12 06:01 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
You can have a decent handling street car with all rubber bushings. I did back in the mid '70s. Only 2 things I added was a front and rear anti-sway bars from Addco. The rear was a common setup using tried and tru links with rubber bushings. The front bar had 'solid' links using hime rods and no rubber bushings. The springs were all stock and so the ride was about the same as stock, but it turned great and mostly flatish.
The car was a '71 Sebring with a 318 engine, then I installed a 273 out of a '66 Barracuda S. Ran and handled great, even on the 1/4 mile oval at Port Angeles, Wa.
Just depends what all you are going to do with it, and how extensive you want to modify it.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#1155388
01/12/12 06:39 PM
01/12/12 06:39 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Poly is going to firm it up over the OEM rubber bushings. The offset bushings are used for better adjustment for Caster and Camber.. Energy Susp quit producing the poly lowers because they didnt hold tight like the OEM bushings. They said a lot of people were complaining about them floating back and forth.
I am truckless..
[Re: DaytonaTurbo]
#1155389
01/13/12 12:32 AM
01/13/12 12:32 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
A year or so ago I started buying parts for my front end rebuild and soon I will actually start working on it. At the time I bought a set of poly upper and lower control arm bushings. Now for the rest of my front end I've got 1" torsion bars, stock front swap bar and new poly bushings for everything.
My question is, are the control arm bushings I've bought a good choice or should I look elsewhere? I have heard of offset control arm bushings and I've heard of guys running a mixture of poly and rubber control arm bushings. Will be mostly a street car but trying to set it up to handle half way decently too.
Save the money and just put Moog offset 7103 rubber bushings on the UCA's if those will work with a 73-74 Iso front end B-body.
IIRC, Moog makes an offset upper dog bone for those cars. That will move the front and rear bushing (arms of the A-arm) in or out depending on how you install them.
But does that car take shims for UCA alignment adjustment? If so, just space out the rear and see if you can get 3 degrees of positve caster
[Re: bigtail]
#1155394
01/25/12 08:03 PM
01/25/12 08:03 PM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
I just turned some aluminum k-member bushings for my 74 Charger. After all said and done I should have just gone here... http://www.solidbushings.com/catalog.html and spent $199 for the set. Materials with shipping was about $100 and the oblong shape for the k member was not easy to do without mill. I used Firm Feel's UCA's but haven't done an alignment. Waiting for a WheelFit to measure offset for the big Goodyear Bluestreaks. Also went with big sway and tbars from Firm Feel, Greasable lca pins and bushings.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: bigtail]
#1155395
02/09/12 02:42 AM
02/09/12 02:42 AM
Posts: 16 Minnesota
billrabe
Minnesota
I'm surprised Rick didn't mention this, but the new issue of Mopar Action has a place where you can get offset URETHANE bushings listed. Way better than spongy offset rubber ones. They are from the land down under. Check out the newest issue in the steering upgrade article.
Do you have the part number of the offset UCA bushings from down under that can be used for a 73 B body Charger? The Moog K7103's don't work for the 73s, they are too small. I wonder how much they cost? I don't have access to Mopar Action.
[Re: billrabe]
#1155396
02/09/12 02:56 AM
02/09/12 02:56 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Incarcerated? Homeless? ANYONE with an address can get a subscription, right?
[Re: Mattax]
#1155398
02/09/12 10:59 PM
02/09/12 10:59 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
on welding the boxed plates on the LCA i suggest you put the front end together and set up the alignment first then weld up or atleast tac the plates on with the suspension loaded.. those two stamped pieces have alot of movement. (sort of a sissor effect) and if you weld them loose and off the car..you could adversely effect the amount of adjustment in the alignment. i had this isssue..i boxed up a set when they were loose/off the car...and couldnt get the castor where i needed it..because the supports forced it in a fixed position. after installing a new set then getting my alignment where it needed to be.. we tacted them in loaded..then finish welded them it seemed to work very well after that.. FWIW
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: Rick_Ehrenberg]
#1155399
02/10/12 03:37 AM
02/10/12 03:37 AM
DaytonaTurbo
Manitoba, Canada
Single best mod you can do to a 73-up B-body: SOLID (alum, iron) K-member "isolators". NOT URETHANE. Metal.
Rick E.
Already had that planned. ![](/ubbthreads/images/graemlins/thumbs.gif)
Thanks for the tip! ![](/ubbthreads/images/graemlins/thumbs.gif)
