Re: 22" vs 26" Radiator - Gen 3 Hemi Install
[Re: lakerism]
#1155083
01/12/12 02:39 PM
01/12/12 02:39 PM
Posts: 387 Almont, MI.
gdemon
Almont, MI.
I used a 22" in mine. Had it made at Superior radiator in Mt Clemens Mi.
69 Barracuda
70 Cuda
70 Cuda
70 Cuda Conv.
70 T/A Challenger
70 Sport Fury GT
71 Demon 5.7 Hemi
72 Demon
[Re: lakerism]
#1155084
01/12/12 10:57 PM
01/12/12 10:57 PM
Posts: 669 Michigan, USA
ramman5600
Michigan, USA
You can buy an aftermarket bracket that allows you to mount the 26" radiator. You can also keep the 22" and have it converted to a 4-core for less $$$ and better results.
Do you know if a 4 core with an electric fan and shroud will have enough clearance in a 67 B-body? Also do you know who makes the bracket?
Thx -C
[Re: ramman5600]
#1155085
01/13/12 03:55 AM
01/13/12 03:55 AM
Posts: 402 La Verne, CA
lakerism
La Verne, CA
The 22" is a 2-core from the factory, having it converted to a 4-core does not change the dimensions at all so if it came stock with the 22" then you are fine. As for the bracket, I see them all the time on e-bag, you can also try those guys in Canada that produce all the repop stuff, can't think of their name right now, sorry... Here is the bracket: http://www.ebay.com/itm/70-71-72-73-74-C...ies&vxp=mtr
[Re: lakerism]
#1155086
01/13/12 03:55 PM
01/13/12 03:55 PM
ramman5600
Michigan, USA
So a 4 core 22" should cool as well as a 3 core 26"?
-C
[Re: lakerism]
#1155088
01/15/12 06:28 PM
01/15/12 06:28 PM
ramman5600
Michigan, USA
As well or better since there is more total area of colling fins, be sure to use some good electric fans to compliment it though. Now if you could upgrade that 26" to a 4-core, that would be the ticket
I have seen the 4 core 22" listed as good for 800 HP. Should be adequate for a stock gen 3 hemi even if I supercharge it later on. Am I off?
