8 3/4 Rear Bearings Inspect, Replace or Re use?
#1154624
01/11/12 11:52 AM
01/11/12 11:52 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I have a 8 3/4 housing and axels that came out of a 70 Charger that I bought in 2002. At the same time I picked up a limited slip center section with 3.55 gears. I am getting ready to put it all together now, 9 years later.
I had planned on replacing the bearings but now that I look at it the bearings, axels, races and adjuster all look like they would be OK with a clean up an re-greasing.
Is there some way to check the bearings while it is apart other than just a visual inspection?
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
Re: 8 3/4 Rear Bearings Inspect, Replace or Re use?
[Re: JohnRR]
#1154627
01/11/12 01:22 PM
01/11/12 01:22 PM
dogdays
[Re: dogdays]
#1154628
01/11/12 02:21 PM
01/11/12 02:21 PM
finadk
East Brunswick, NJ
Thanks for the prompt responses. Can anyone tell me what the foam gaskets on the axle retainer plate does? It looks like they are available but im wondering why foam and not some ordinary gasket material?
Scott
1976 Corvette
