8 3/4 Rear Bearings Inspect, Replace or Re use? #1154624
01/11/12 11:52 AM
01/11/12 11:52 AM
East Brunswick, NJ
finadk Offline OP
finadk  Offline OP
East Brunswick, NJ
I have a 8 3/4 housing and axels that came out of a 70 Charger that I bought in 2002. At the same time I picked up a limited slip center section with 3.55 gears. I am getting ready to put it all together now, 9 years later.
I had planned on replacing the bearings but now that I look at it the bearings, axels, races and adjuster all look like they would be OK with a clean up an re-greasing.
Is there some way to check the bearings while it is apart other than just a visual inspection?
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: 8 3/4 Rear Bearings Inspect, Replace or Re use? [Re: finadk] #1154625
01/11/12 11:57 AM
01/11/12 11:57 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
uNder normal operations ...I have NEVER seen a set of axle bearing that have needed replacement EVEN when there has been neglect on greasing.
JUST my experience.
Re: 8 3/4 Rear Bearings Inspect, Replace or Re use? [Re: finadk] #1154626
01/11/12 12:59 PM
01/11/12 12:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Clean the grease out real good using brake parts cleaner , do it into a clean white rag , look for metal debris. soak it in mineral spirits and then blow it out , pull the race up against the rollers with your hand and turn it if the bearing is bad you will feel it .
Re: 8 3/4 Rear Bearings Inspect, Replace or Re use? [Re: JohnRR] #1154627
01/11/12 01:22 PM
01/11/12 01:22 PM
dogdays Offline
dogdays  Offline
Yup.
R.
Re: 8 3/4 Rear Bearings Inspect, Replace or Re use? [Re: dogdays] #1154628
01/11/12 02:21 PM
01/11/12 02:21 PM
East Brunswick, NJ
finadk Offline OP
finadk  Offline OP
East Brunswick, NJ
Thanks for the prompt responses. Can anyone tell me what the foam gaskets on the axle retainer plate does? It looks like they are available but im wondering why foam and not some ordinary gasket material?
Re: 8 3/4 Rear Bearings Inspect, Replace or Re use? [Re: finadk] #1154629
01/11/12 02:54 PM
01/11/12 02:54 PM
JohnRR Offline
JohnRR  Offline
It's a gasket , why foam ??? you could use gasket material if you want , many just use RTV
