Hey I am new to the forum and hoping for a little advice.
I have a 440 stroked to 493 using 440 source parts.
440 source heads untouched
comp pro magnum 1.5 rockers
holley street dominator with holley 850 dp
hooker 2 in headers with 3.5 inch collectors and 3 inch exhaust
comp cams xe295hl .564/.564 lift 251 intake duration/257 exhaust duration hydraulic flat tappet
comp ratio should be 9.6ish:1
initial timing 18/total 38
The car is a 70 cuda with a 4 speed and 28 inch m/t drag radials
car ran a best of
12.55@111 with 3.23 gears and suregrip
Now I have 3.91s in it and some homemade caltracs with stock springs.
Firts I was wondering if you think I willll see any improvement in et or mph with the gear change?
Next I was looking at the mopar 590 cam but my compression is to low for that.
my dynamic compression ratio comes out to 7.15:1 with the current cam. I am curious do you think it would be worth it to try a set of 1.6 ratio rockers and what would that do to the dcr? That would put the lift at about .600 that would potentially let me run the stock stealth springs which are recommended to .600 max lift.
never been on the dyno so doing different testing at the track.
the car has a stumble when you stab the throttle under 3000 rpm i have some accelerator pump cams i think its getting to much fuel also need to jet it its running a little rich.
Really hoping to learn a thing or two.
Thanks, Cody
