Turn-Down Tailpipes on '68 Charger R/T #1154341
01/10/12 10:33 PM
01/10/12 10:33 PM
Raleigh, NC
Meangreen68 Offline OP
Raleigh, NC
When I bought my car it had California black plates since new. It also had turn-down tailpipes. They weren't turn-down clamp-on tips either. The turned-down portion was formed in the pipe and looked original. Is that possible?
I've attached my broadcast sheet, but I'm not sure if reflects what type of exhaust was ordered.
I kind of like the turn-down look more than the polished straight tips found on most '68 Chargers.
I have new TTI ceramic headers in storage and was wondering if TTI makes a molded turn-down tailpipe?
John
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154342
01/10/12 10:54 PM
01/10/12 10:54 PM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
Yes all California cars had turn down exhaust because of emissions.
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Ron69rr] #1154343
01/11/12 02:30 AM
01/11/12 02:30 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Noise Reduction Package, N95 I think. Same for CA Roadrunners.
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Ron69rr] #1154344
01/11/12 02:53 AM
01/11/12 02:53 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Not even CLOSE to being true.
In the "ballpark", but ONLY for 1970, N95 - CA emissions & N97 - noise reduction.
The '68 Parts Catalog indicates NO differences for CA vehicles & only shows one pair of Charger R/T 440 tailpipes.
The Charger R/T in BULLITT has tips & was purchased off a lot for the movie.
Nothing on your b'cast sheet is any different than another 440 auto a/c '68 Charger R/T.
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154345
01/11/12 03:51 AM
01/11/12 03:51 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I believe NON R/T cars had turn downs, example is a XP Charger with 383, no chrome tips.
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154346
01/11/12 11:30 AM
01/11/12 11:30 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
.. i like turn downs better too, but when you start it you blow dust everywhere including near by cars..if that matters.
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154347
01/11/12 04:08 PM
01/11/12 04:08 PM
Raleigh, NC
Raleigh, NC
I went on TTI's website and they do have turn-down tips in 16ga aluminized steel. http://www.ttiexhaust.com/Exhaust%20Tips/Tips.htm#tdt
They're slip on though. They look good but I don't want to have clamps visible.
Can aluminized steel tips be tig welded to their 2-1/2" exhaust system for a cleaner look?
I added my fender tag just in case it notes turn-down pipes.
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154348
01/11/12 08:16 PM
01/11/12 08:16 PM
moparmadman69 Offline
Colby Boyce
Tech, Sales & Customer Service
Accurate Ltd.
541-672-2661
http://www.accurateltd.com/
accurateexhaustltd@outlook.com
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: moparmadman69] #1154349
01/11/12 10:16 PM
01/11/12 10:16 PM
Raleigh, NC
Raleigh, NC
Madman, that's exactly how they looked! The turned-down end didn't face straight down like the TTI tips do, they flared slightly like yours.
I also noticed that your exhaust pipes are made with thicker aluminized steel, 14 gauge vs TTI's 16.
In a box, I have TTI's 1-7/8" ceramic coated 440 headers w/3" collectors, does your 2-1/2" "H" pipe system bolt directly to their headers? If not, do you guys plan to offer a version that would?
Wow, is all I can say. Thanks for chiming in.
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154350
01/11/12 11:37 PM
01/11/12 11:37 PM
Los Altos Hills, CA
Dans 68 Offline
Dans 68  Offline
Los Altos Hills, CA
...I added my fender tag just in case it notes turn-down pipes.
The tag would not note anything regarding the tail pipes.
Dan
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154351
01/13/12 03:37 PM
01/13/12 03:37 PM
We don't make a bolt up H-pipe to any header system expect Schumacher Tri-y's. Our customers have taken our h-pipes and modified them to fit headers but we don't make anything. Mostly what we do is make factory style exhaust up to the stock exhaust manifolds. We can modify and customize to a point but each set of headers is different and without making a 5 piece H-pipe with a lot of adjustability there isn't a good way to make a universal H-pipe. If you are in need of tail pipes or mufflers give me a call and I can help you out.
Thank you,
Colby Boyce
Accurate Ltd.
541-672-2661
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: moparmadman69] #1154352
01/14/12 08:01 AM
01/14/12 08:01 AM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
here are my TTI turn downs..shackles were removed the first week of owning the car..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: 6bblgt] #1154353
01/14/12 05:51 PM
01/14/12 05:51 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
they were probably replaced and the owner didn't want to spring for new tips is all.. very common to see that.. i have yet to see any 68 R/T without tips.. does your still have the tip mounts? or can you tell if they were ever there? heck even my 71 sport fury GT has the 70 style tip mounts carried over.... dan
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: ph23vo] #1154354
01/14/12 08:13 PM
01/14/12 08:13 PM
Raleigh, NC
Raleigh, NC
Hey Dan,
Are these the parts? I dismantled the car in 1999. I took tons of photographs but in 2001 my computer crashed and I lost them all. I'm going to need a lot of help getting this car back together.
As I took parts off the car they were sandblasted, epoxy primed, and then sprayed with black Centari.
The best that I can recall, the pipes weren't very large in diameter, maybe around 2-1/4". I disposed of the pipes back then.
I did look in the 1968 parts book and the photograph of the standard Charger (page 23-252) had turn-downs, and the next page, 23-254, showed the R/T with chrome tips.
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154355
01/15/12 01:26 PM
01/15/12 01:26 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
yep tip mounts and brackets! dan
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154356
01/16/12 05:49 PM
01/16/12 05:49 PM
Raleigh, NC
Raleigh, NC
I called Mike at TTI today to see if they could modify there straight 68-70 B-body tailpipes by bending a turn-down at the end. He said no.
Then I got on the phone with Tom at Accurate. Super-nice folks. It was recommended to get with TTI and buy the adapter for their headers transitioning to a stock 2-1/2" exhaust system. I can then go with Accurate's H-pipe exhaust from there.
Accurate won me over with the use of thicker aluminized steel and the molded-in turn down tailpipe option.
My only other decision is the diameter of the tailpipes. 2-1/4" or 2-1/2". My engine is a 440 quench motor, 3.9" offset-ground factory crank, 6.89" Manley I-beams, E-heads, Diamond flat-tops, Engle K60/62 cam, 727 auto, 3.55 rear, and I'm after low-end torque. Tom suggested 2-1/4".
The engine is in the crate, no bench-dyno numbers yet, with no converter selected, and I have no idea what carb to use. I do have a new Weiand 7500 intake. It'll be a street-driven car.
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154357
01/16/12 06:19 PM
01/16/12 06:19 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I believe 383 cars had the turn down and R/T had chrome extensions
Re: Turn-Down Tailpipes on '68 Charger R/T [Re: Meangreen68] #1154358
01/16/12 07:18 PM
01/16/12 07:18 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
