Update: suspension rebuild
#1154038
01/10/12 05:11 PM
01/10/12 05:11 PM
Posts: 3,344 Central TX
roe
Central TX
Getting ready to redo my front suspension on Friday and am looking for tips, it's my first time. I have a polygraphite bushing kit and will lube properly. I know I'm not supposed to torque everything down until weight is back in the suspension, so do I reassemble, put the wheels on, then lower the car down and torque everything? Does that apply to everything in the suspension, or are there some parts that you do torque down while suspension is hanging?
what's the proper procedure for reinstalling the torsion bars?
What are common mistakes that are made?
Any tricks to removing, reinstalling the ball joints.
I have the Mancini kit for the control arm bushings, anything special here? Any mistakes to avoid so I don't have to replace a bushing that I tear up from improper procedure? I also know that lca bushings have to be pressed in at a machine shop.
Do you guys grease all your joints before assembly or after?
I have a second set of factory lca's off the car already with sway bar tabs. They were painted black to prevent rust while they were sitting. I need to strip all this paint off area that will be inside the hub and bearings right. Is a wire wheel ok, or is it too rough? Should I strip it chemically instead?
Any and all tips are welcome. I really don't want to tear it down and screw up something from not knowing.
Thanks in advance Roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: suspension rebuild pitfalls or advice
[Re: roe]
#1154039
01/10/12 06:10 PM
01/10/12 06:10 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Just support the car with jackstands under the control arms and the wheels and brakes off. Makes it a lot easier to access all of the bolts for proper torque vs trying to do it on ramps or something.
If you want to remove your upper ball joints easily and you don't have an impact gun, just get Harbor Freight's biggest possible adjustable wrench (the one that's like two and a half feet long) and unscrew them with the upper arms still on the car. Super easy on the original joints on my Coronet.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: Secret Chimp]
#1154040
01/10/12 08:19 PM
01/10/12 08:19 PM
roe
Central TX
Thanks, that's exactly the type of stuff I'm looking for. I have a pair of ramps and probably would have used a bunch of four letter words while trying to snake my arms through the suspension to reach all the bolts. And the big wrench on the UBJ while the UCA is still on the car is a good one too
Anyone else?
[Re: roe]
#1154041
01/10/12 10:24 PM
01/10/12 10:24 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Getting the old torsion bar pivot bushings out of the LCA was a learning curve for me. I think someone here told how to do it. Here are some pics of my process in case you are replacing them. 1. Use the Mancini tool to pull out the bushing, usually you only get the inner steel tube and rubber. 2. The difficulty and reason for this advice is: 90% of the time it leaves the outer steel sleeve inside the LCA. 3. Identify the sleeve left in the LCA and cut 4 slots in the walls of the sleeve that project out from the LCA. 4. Use a chisel and hammer to collapse each of the 4 sides inwards. This creates that funny '4-star' shape of the sleeve after removal in the pic below. The goal as you might imagine from the pics below is to create a condition in which you can use a slide-hammer to hammer the sleeve out from the LCA... (In the pic below, the threaded rod and bolt with giant socket is my home-made slide hammer). The collapsed walls provide something that grabs the slide hammer. A bit complicated to explain in words, I hope the photos help.... good luck!
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: rapom]
#1154045
01/11/12 03:06 PM
01/11/12 03:06 PM
roe
Central TX
Hey guys, a few post back ahy mentions that since I'm using poly bushings that I may not have to remove the outer bushing shells, is this true? If so that would be a major plus.
Thanks roe
[Re: BTTG]
#1154047
01/13/12 06:40 PM
01/13/12 06:40 PM
roe
Central TX
I may just end up having the LCA bushings pressed in and out at a Machine shop and be done with it. Everything else I can do on my own.
So do you guys grease all of the tie rods and ball joints before or after assembly?
[Re: roe]
#1154048
01/13/12 07:05 PM
01/13/12 07:05 PM
Posts: 1,565 tennessee
pushbutton
tennessee
I do it after.
[Re: roe]
#1154052
01/15/12 06:44 PM
01/15/12 06:44 PM
roe
Central TX
Will likely pick up a press from Harbor freight so I can do it myself next time, it wont cost but a couple of bucks more.
[Re: roe]
#1154053
01/24/12 12:59 AM
01/24/12 12:59 AM
roe
Central TX
Well, I just finished up my suspension rebuild and I am smiling from ear to ear. I used poly everywhere, including the LCA and used plenty of the supplied lube/grease when assembling and no squeaks for me. The steering is much tighter than before, not so loose feeling and sloppy. Its more responsive, and the ride is also so much smoother and tracks so much better. And thats just with an eyeball alignment from me. I tried to make the new tie rod assemblies the same size as the ones that came off. And after reassembly I adjusted the UCA for max caster, set ride height and torqed everything down. Then I just eyeballed the wheels to make sure they were generally pointing in the same direction the same amount with the same amount of "tilt". Then took it for a test drive. All I can say is wow. I cant wait until I get my new tires, toss my rims back on, and get a real alignment. This is so much better.
I always thought that my suspension was not that bad, boy was I wrong. Now, if I were to upgrade to a FirmFeel stage II box, that would be icing on the cake. roe
[Re: roe]
#1154054
01/24/12 02:48 AM
01/24/12 02:48 AM
Secret Chimp
Eugene, Oregon
What vendor(s) did you use for your rebuild?
