Update: suspension rebuild #1154038
01/10/12 05:11 PM
01/10/12 05:11 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Getting ready to redo my front suspension on Friday and am looking for tips, it's my first time. I have a polygraphite bushing kit and will lube properly. I know I'm not supposed to torque everything down until weight is back in the suspension, so do I reassemble, put the wheels on, then lower the car down and torque everything? Does that apply to everything in the suspension, or are there some parts that you do torque down while suspension is hanging?
what's the proper procedure for reinstalling the torsion bars?
What are common mistakes that are made?
Any tricks to removing, reinstalling the ball joints.
I have the Mancini kit for the control arm bushings, anything special here? Any mistakes to avoid so I don't have to replace a bushing that I tear up from improper procedure? I also know that lca bushings have to be pressed in at a machine shop.
Do you guys grease all your joints before assembly or after?
I have a second set of factory lca's off the car already with sway bar tabs. They were painted black to prevent rust while they were sitting. I need to strip all this paint off area that will be inside the hub and bearings right. Is a wire wheel ok, or is it too rough? Should I strip it chemically instead?
Any and all tips are welcome. I really don't want to tear it down and screw up something from not knowing.
Thanks in advance
Roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: suspension rebuild pitfalls or advice [Re: roe] #1154039
01/10/12 06:10 PM
01/10/12 06:10 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Just support the car with jackstands under the control arms and the wheels and brakes off. Makes it a lot easier to access all of the bolts for proper torque vs trying to do it on ramps or something.
If you want to remove your upper ball joints easily and you don't have an impact gun, just get Harbor Freight's biggest possible adjustable wrench (the one that's like two and a half feet long) and unscrew them with the upper arms still on the car. Super easy on the original joints on my Coronet.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: suspension rebuild pitfalls or advice [Re: Secret Chimp] #1154040
01/10/12 08:19 PM
01/10/12 08:19 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Thanks, that's exactly the type of stuff I'm looking for. I have a pair of ramps and probably would have used a bunch of four letter words while trying to snake my arms through the suspension to reach all the bolts. And the big wrench on the UBJ while the UCA is still on the car is a good one too
Anyone else?
Re: suspension rebuild pitfalls or advice [Re: roe] #1154041
01/10/12 10:24 PM
01/10/12 10:24 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Getting the old torsion bar pivot bushings out of the LCA was a learning curve for me. I think someone here told how to do it. Here are some pics of my process in case you are replacing them.
1. Use the Mancini tool to pull out the bushing, usually you only get the inner steel tube and rubber.
2. The difficulty and reason for this advice is: 90% of the time it leaves the outer steel sleeve inside the LCA.
3. Identify the sleeve left in the LCA and cut 4 slots in the walls of the sleeve that project out from the LCA.
4. Use a chisel and hammer to collapse each of the 4 sides inwards. This creates that funny '4-star' shape of the sleeve after removal in the pic below.
The goal as you might imagine from the pics below is to create a condition in which you can use a slide-hammer to hammer the sleeve out from the LCA... (In the pic below, the threaded rod and bolt with giant socket is my home-made slide hammer). The collapsed walls provide something that grabs the slide hammer.
A bit complicated to explain in words, I hope the photos help.... good luck!
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: suspension rebuild pitfalls or advice [Re: 67SATisfaction] #1154042
01/10/12 11:40 PM
01/10/12 11:40 PM
IN
ahy Offline
ahy  Offline
IN
Sounds like a good plan and I can vouch for the Mancini kit. I followed the procedures in the factory service manual with the Mancini kit and got my 40 year old suspension apart without problem or drama. A decent service manual, FSM preferred, helps a lot.
Just a couple of suggestions. With poly bushings you will likley need to keep the outer steel sleeve in place for the LCA and UCA - you may not have to fight it out. The instructions with the kit should tell you.
With the Mancini kit, you should have a socket for the upper ball joint. As posted, remove the ball joint with the UCA in the car. You will likley need a stout breaker bar and 3-4' of pipe to get it started. Have good jack stands under it and watch carefully when you are pulling. Needless to say, several shots of penetrating oil hours or days before you disassemble can only help.
Putting the T bars in is straight forward. Just make sure the adjusters are backed off all the way, bump stops removed, shocks removed and they should fit correctly.
Good luck and have fun!
Re: suspension rebuild pitfalls or advice [Re: ahy] #1154043
01/10/12 11:53 PM
01/10/12 11:53 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
To remove that lower control arm bushing shell, the outer one that is such a pain, try this...Get a 1-3/8" tap (I found one on e-bay for 12 dollars), thread this large tap into the bushing shell, then take it to a press and use the tap to press against or remove the tap and get a 1-3/8" bolt and press against that. This is the easiest way to do this. Good luck.
Re: suspension rebuild pitfalls or advice [Re: 469runner] #1154044
01/11/12 09:28 AM
01/11/12 09:28 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
After you get the rubber out of the LCA, you can weld a washer to the bushing and push the bushing out with a press. (If you have a press)
I was always told it was ok to use poly in everything but not the LCA (use rubber)because of possible squeaks even with lube on them.
Use penatrating fluid up to a week before on the torsion bars and Upper control arm bushing.
Might want to weld in the lower control arm reenforcement plates that mancini sells while you have them out.
Re: suspension rebuild pitfalls or advice [Re: rapom] #1154045
01/11/12 03:06 PM
01/11/12 03:06 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Hey guys, a few post back ahy mentions that since I'm using poly bushings that I may not have to remove the outer bushing shells, is this true? If so that would be a major plus.
roe
Re: suspension rebuild pitfalls or advice [Re: 469runner] #1154046
01/11/12 03:43 PM
01/11/12 03:43 PM
PA
BTTG Offline
BTTG  Offline
PA
What an easy/cheap way to do this....
seen many posts on this before and never heard of this approach.
http://www.ebay.com/itm/Greenfield-Tap-D...=item27c15e8a4b
Re: suspension rebuild pitfalls or advice [Re: BTTG] #1154047
01/13/12 06:40 PM
01/13/12 06:40 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I may just end up having the LCA bushings pressed in and out at a Machine shop and be done with it. Everything else I can do on my own.
So do you guys grease all of the tie rods and ball joints before or after assembly?
Re: suspension rebuild pitfalls or advice [Re: roe] #1154048
01/13/12 07:05 PM
01/13/12 07:05 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I do it after.
Re: suspension rebuild pitfalls or advice [Re: pushbutton] #1154049
01/13/12 07:40 PM
01/13/12 07:40 PM
BDW Online content
BDW  Online Content
I fought with the 1st LCA inner bushing, chiseling and beating.
Crazy IMO, and you chance damaging the sleeve.
Got this for the 2nd side. Kinda expensive, might be worth it to just pay the machine shop to do both sides, in & out.
http://www.americanmuscle.biz/23501_Lower_Control_Arm_Bushing_Sleeve_Remover_ABE_p/23501.htm
Re: suspension rebuild pitfalls or advice [Re: BDW] #1154050
01/13/12 09:38 PM
01/13/12 09:38 PM
Retired now in Tennessee
Chi_Town_Runner Offline
I agree. But the expense is worth it. I have seen machine shops [Edited by Moparts - Family Friendly Site - Keep it clean] up a LCA. Not everyone will treat parts like it's their owm.
Expensive, but a good investment, especially if you hang out with a Mopar bunch.
Good Luck
FRank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: suspension rebuild pitfalls or advice [Re: Chi_Town_Runner] #1154051
01/15/12 06:41 PM
01/15/12 06:41 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Well, I decided to just let the machine shop handle pulling and replacing of the LCA bushings. Ahy was right in that since I was using poly LCA bushings, that the outer bushing shell was not to be removed from the LCA. The inner shell was reused as well. If I had went with rubber they would have come with a new inner/outer shell, already assembled and would have been an easier job for the machine shop, a simple press in and out.
heres a pic of the finished job. Im happy. Paid him $60. Would have been $40 but I gave him an extra $20 for coming in on his day off to knock this out for me, so that I could try and keep my schedule.
Re: suspension rebuild pitfalls or advice [Re: roe] #1154052
01/15/12 06:44 PM
01/15/12 06:44 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Will likely pick up a press from Harbor freight so I can do it myself next time, it wont cost but a couple of bucks more.
Re: suspension rebuild pitfalls or advice [Re: roe] #1154053
01/24/12 12:59 AM
01/24/12 12:59 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Well, I just finished up my suspension rebuild and I am smiling from ear to ear. I used poly everywhere, including the LCA and used plenty of the supplied lube/grease when assembling and no squeaks for me. The steering is much tighter than before, not so loose feeling and sloppy. Its more responsive, and the ride is also so much smoother and tracks so much better. And thats just with an eyeball alignment from me. I tried to make the new tie rod assemblies the same size as the ones that came off. And after reassembly I adjusted the UCA for max caster, set ride height and torqed everything down. Then I just eyeballed the wheels to make sure they were generally pointing in the same direction the same amount with the same amount of "tilt". Then took it for a test drive. All I can say is wow. I cant wait until I get my new tires, toss my rims back on, and get a real alignment. This is so much better.
I always thought that my suspension was not that bad, boy was I wrong. Now, if I were to upgrade to a FirmFeel stage II box, that would be icing on the cake.
roe
Re: suspension rebuild pitfalls or advice [Re: roe] #1154054
01/24/12 02:48 AM
01/24/12 02:48 AM
Eugene, Oregon
Eugene, Oregon
What vendor(s) did you use for your rebuild?
Re: suspension rebuild pitfalls or advice [Re: Secret Chimp] #1154055
01/24/12 08:02 PM
01/24/12 08:02 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Suspension bushings degrade slowly over time. Replacing the components all at once displays immediately what was lost. It often IS dramatic!
Re: suspension rebuild pitfalls or advice [Re: Secret Chimp] #1154056
01/24/12 08:22 PM
01/24/12 08:22 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Secret Chimp: I used this kit http://www.performancesuspension.com/pro...roducts_id=5918 . With the discout and free shipping it was only about $260 for a full poly kit.
Frankenduster: its amazing the difference I feel without even touching the stock p/s box. I think the FF stage II box would be a nice edition. I wouldnt be surprised if all those balljoints and tie rod ends were all original, they would all just flop around when you held them in your hand. I'll have to check them, see if there are any chrysler part #'s or logos on them.
roe
Re: suspension rebuild pitfalls or advice [Re: roe] #1154057
01/24/12 08:38 PM
01/24/12 08:38 PM
Gambrills, Md
mopork Offline
mopork  Offline
Gambrills, Md
ROE
I love your satellite it's my favorite body style
