hi perf 440 timing curve
#115382
09/05/08 02:46 AM
09/05/08 02:46 AM
hi i have 69 roadrunner thats tubbed with a 4 link and ford 9 inch.the engine is a 440 bored .30 over with forged dome pistons im guessing about 11 to 1 compression,292comp cam, ported 944 heads,torkerII intake with a 2 inch spacer,barry grant 850 cfm carb,and large tube headers, 3 inch exhaust.after many problems with the stock ignition i installed an msd 6al box and an msd pro billet distributer. runs much better now but i havent messed with the springs or stoppers in the distributer yet and i know there not right cant seem to find any info on correct timing curve,what initial,what toatal and the curve any advice would be super helpful
Re: hi perf 440 timing curve
[Re: Big-Mike]
#115385
09/05/08 03:22 AM
09/05/08 03:22 AM
this msd pro billet dist has a few different stoppers to set toatal timing and a few different sets of springs for the curve it does seem to run best with about 15-20 degrees initial and you answered about the toatal but do you know what rpm it should be toataly advanced thanks for the help
#115387
09/05/08 04:02 PM
09/05/08 04:02 PM
Posts: 6,516 Santa Cruz, California
Lefty
Someone at Pertronix must read Mopar Action. When I verified the curve in my new Pertronics distrubitor it matched these specs from the Mopar Action archives to the letter. The 440 in my 66 Coronet runs very nice now. http://www.moparaction.com/Tech/quest/SLOW_CURVE.html Quote:
Bob, assuming sufficient octane vs. C.R., you need a curve something close to this:
Under 1400RPM - no advance - set initial at 15 degrees BTDC 2000 - 10 dergees mech (25 total) 2500 - 20 degrees mech (35 total) - all in.
Plus, at LEAST 15 degrees of vacuum advance under light throttle (50 deg. total, 52-55 better).
If it currently doesn't go to full advance until 5500, you're giving up lots of power.
If it currently has less (or no) vacuum advance), you're giving up LOTS of fuel economy and fouling plugs.
Rick
