E Body Trunk Lamp Switch? #1153516
01/09/12 04:44 PM
01/09/12 04:44 PM
MI
hemiviper588 Offline OP
MI
Does anyone know if this is the correct trunk lamp switch for a 70-71 Cuda or Challenger? Thanks in advance...
Re: E Body Trunk Lamp Switch? [Re: hemiviper588] #1153517
01/09/12 05:21 PM
01/09/12 05:21 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The trunk light should use a mercury switch.
Re: E Body Trunk Lamp Switch? [Re: hemiviper588] #1153518
01/09/12 05:48 PM
01/09/12 05:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
no, like mentioned e-bodies do not use a switch
Re: E Body Trunk Lamp Switch? [Re: burdar] #1153519
01/09/12 05:52 PM
01/09/12 05:52 PM
MD
floyd Offline
floyd  Offline
MD
Sorry, but I couldn't help but remember this line from Lethal Weapon:
"..I haven't seen anything like this since the war. The CIA used to hire mercs. They used the exact same setup... Mercury switches, that's heavy s***."
Re: E Body Trunk Lamp Switch? [Re: gtx6970] #1153520
01/09/12 05:53 PM
01/09/12 05:53 PM
MI
MI
Thanks, so did the A and B body used a switch like this? Or did they use a mercury switch as well in 70 71?
Re: E Body Trunk Lamp Switch? [Re: hemiviper588] #1153521
01/09/12 05:57 PM
01/09/12 05:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
correct,
B-bodies use this style switch , at least 66-70 did ( sorry, I have no idea on A-bodies )
Re: E Body Trunk Lamp Switch? [Re: gtx6970] #1153522
01/16/12 04:30 AM
01/16/12 04:30 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Original trunk light assembly removed from a '73 Scamp:
Blurry pic of the switch in place:
Lamp mounted:
You can barely see the switch in place here:
