6.1 hemi install - alternator wiring help #1153296
01/09/12 12:23 AM
01/09/12 12:23 AM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
What's the best way to deal with the higher output Alternator that comes with the 6.1?
Thx.
-C
Re: 6.1 hemi install - alternator wiring help [Re: ramman5600] #1153297
01/09/12 08:28 PM
01/09/12 08:28 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Run it directly from the output terminal to the positive terminal of the battery.
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 6.1 hemi install - alternator wiring help [Re: wldtm] #1153298
01/10/12 12:04 AM
01/10/12 12:04 AM
Michigan, USA
Michigan, USA
What about using the gauges (volt meter change?) etc
Re: 6.1 hemi install - alternator wiring help [Re: ramman5600] #1153299
01/10/12 10:04 AM
01/10/12 10:04 AM
NY usa
540challenger Offline
NY usa
You could tap into any 12v source to get the volt meter to read granted the closer to the battery the better. You could run the volt meter direct to the battery if you want. Just make sure you use a relay inbetween and wire that to a key on source so your gauge is not always on.
