1973 roadrunner console ? #1153075
01/08/12 08:16 PM
01/08/12 08:16 PM
north carolina usa
beeson44 Offline OP
beeson44  Offline OP
north carolina usa
I have a 318 4 speed rr that is becoming 470 lowdeck 4 speed,My question is the car factory was 3 speed in floor and dad put 4spd in in late 70`s I have a foctory auto console and would love to make it 4spd in console would the auto console work.If so what would need to be changed to make it work.I didn`t no if the shifter was further back in a console car.Any help would be great thanks.
Re: 1973 roadrunner console ? [Re: beeson44] #1153076
01/08/12 08:29 PM
01/08/12 08:29 PM
IMGTX Offline
IMGTX  Offline
The top metal insert is different. The hole is larger to accommodate the shift boot. You can get new plates or enlarge the one you have.
Also the side of the base has a larger cut out. Somebody used to sell a template to trim an Auto console to make it a manual console or you can just trim as needed to be sure it doesn't damage the shift boot.
Lastly, you will also have to make a new front console mount as the Auto console uses the same bracket that holds the shifter but it isn't a big deal.
Re: 1973 roadrunner console ? [Re: beeson44] #1153077
01/08/12 08:32 PM
01/08/12 08:32 PM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
Yes it will work with some modifications. You will need a 4 speed top plate and you will have to trim your auto console to fit around the 4 speed hump. There is a pattern floating around some where on the web but if you purchase the top plate from some ebag sellers they will usually include the pattern.
Re: 1973 roadrunner console ? [Re: beeson44] #1153078
01/08/12 11:56 PM
01/08/12 11:56 PM
north carolina usa
beeson44 Offline OP
beeson44  Offline OP
north carolina usa
Is the hump different or will it work.
Re: 1973 roadrunner console ? [Re: beeson44] #1153079
01/09/12 12:11 AM
01/09/12 12:11 AM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
Yes humps the same.
Re: 1973 roadrunner console ? [Re: Ron69rr] #1153080
01/10/12 01:41 AM
01/10/12 01:41 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes humps the same.
Assuming your hump is in the bucket seat position not in the bench seat position.
Re: 1973 roadrunner console ? [Re: DaytonaTurbo] #1153081
01/10/12 11:57 PM
01/10/12 11:57 PM
north carolina usa
beeson44 Offline OP
beeson44  Offline OP
north carolina usa
I thought the hump was different what about shifter set back,my car was bench factory w3spd.
Re: 1973 roadrunner console ? [Re: beeson44] #1153082
01/11/12 12:27 AM
01/11/12 12:27 AM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
I think the humps are different for b bodies with bench or buckets. E bodies are all the same because you could not get bench with a 4 speed. I thought from our question it had buckets in it already. Brewers can set you up with the right hump.
Re: 1973 roadrunner console ? [Re: Ron69rr] #1153083
01/11/12 12:35 AM
01/11/12 12:35 AM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
I just checked there web site and they have some good used ones for 60 off.
Re: 1973 roadrunner console ? [Re: Ron69rr] #1153084
01/12/12 05:17 AM
01/12/12 05:17 AM
Manitoba, Canada
Manitoba, Canada
Yes, for the 71-74 b bodies, the hump is different for bench versus bucket. You will need a bucket hump if you want to use a stock console. If you decide you want to buy a hump, PM me as I have a new in box one I no longer need.
