72 Duster Tail Panel, How Hard to Replace? #1153020
01/08/12 07:13 PM
01/08/12 07:13 PM
Maryland
Dads426 Offline OP
Dads426  Offline OP
Maryland
Looking at buying a '72 340 Duster, but the tail panel is pretty trashed (not dented, mostly rust & bondo). I have a lot of experience with floor pans and patch panels, but the tail panel is a little daunting. How hard are they to replace and keep everything aligned (I'm thinking a temporary brace will be required). Thanks!
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: 72 Duster Tail Panel, How Hard to Replace? [Re: Dads426] #1153021
01/08/12 08:00 PM
01/08/12 08:00 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I'm getting ready to replace one in my bro-in-laws 72. There are numerous spot welds to drill out around the perimeter. YES, a brace along the top edge would be helpful.
Re: 72 Duster Tail Panel, How Hard to Replace? [Re: Kern Dog] #1153022
01/08/12 09:33 PM
01/08/12 09:33 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
400 or so spotwelds to drill out. I didnt brace the Demon I did since the trunk floor was still in, turned out fine
Re: 72 Duster Tail Panel, How Hard to Replace? [Re: rjsjea] #1153023
01/08/12 09:37 PM
01/08/12 09:37 PM
Maryland
Dads426 Offline OP
Dads426  Offline OP
Maryland
I think I might need a few of the Blair spotweld cutters
Thanks for the reply.
Re: 72 Duster Tail Panel, How Hard to Replace? [Re: Dads426] #1153024
01/09/12 11:48 AM
01/09/12 11:48 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I replaced my tail panel on my '71 340 Duster.
First thing. The one from AMD is wrong. The panel will fit OK, but the trunk lock stamping is wrong. It's ok if you don't care about it being right. I got my tail panel from a friends car (wait till he finds out it's missing, ha!). It takes a lot of spot weld cutting and time. But just go at a slow pace, and take it easy. Another thing is, spot welding it back on. We used a spot welder with a long cable, hand held lead. The ones with the crab type pincers will only work to get to some of the weld spots. As far as something to hold the car in square, I didn't use anything. The trunk floor was never taken out. Everything came out square and trus. Just check it every so often.
Here's a pic of the tail panel I used.
Also, check for any rust spots on the metal your going to spot weld to, and replace it.
